Arnova 10 G2 bricked after firmware upgrade
hobbesVT
2012/05/25 - 19:05
hobbesVT said
Has this been ever resolved?
I've exactly the same issue - my ARNOVA splash screen is stuck after an hour - nothing loaded yet.
I can't get rockchip to recognize the device since I can't get it into recovery mode. Whenever I press vol+ and the reset, it immediately goes black (no 15 secs) and when I power it up again, it's stuck at the same place.
And yes, I've tried to press the buttons for 20secs and more ...
Any other ideas by someone? I might have really bricked this one - would really hope to find a way to recover though ... btw, I've tried to root the kasty-ez_arn10g2-23-111.zip
Any help would be most appreciated ...
When the screen goes black, you are in recovery and shouldn't touch the tablet anymore.
You just need to make sure Rockchip flashing tool recognize the tablet (it should show a green square). If this does not happen, please refer to troubleshooting section on the Rockchip flasher page.
Thanks for the reply - that's what I thought as well, but it never got recognized by rockchip. I've meanwhile found a slightly different procedure for getting into recovery mode that I'll repeat here:
- hold the volume + button
- press the reset button for two seconds and release while STILL HOLDING the volume buttom
- after few seconds the tablet will go into recovery mode, and the device driver search will pop-up on your PC
Btw, I'm on a w7-64bit system and the driver did not install correctly. However, going to the device manager and manually installing the driver for the failed device (yellow triangle) from the 64bit w7 directory did the trick and installed correctly.
Rockchip now sees my device - and I hope all goes well from here ...
tomy00
2012/10/14 - 12:52
Hello after install rom update.AR10G2.cramfs.2G.MorkaMod.v1.15.img, the tablet start with a android logo in the screen then reset and dosnt start, screen black.
 I cant put it in recover mode, it dosnt start, cant anyone help me?.
 Thanks.
benthesheep24
2012/11/07 - 20:49
I solved this by simply holding down the reset button with a paperclip for about 30 minutes while plugged into the charging port until I thought it would have enough power to start up, now it is on and hopefully charging.
I suggest leaving it on standby until it has plenty of charge!
Hope this helps someone.
98 Guest(s)
Devices in use: Desktop (83), Phone (15)
heftpflaster
rk.13
