[ ROM ] Arnova 10 G2 Android 4.2.2 custom firmware (AOSP 4.2.2_r1 Test Build v1.3) with root and Google Play Store
jsgage
manchester UK
2013/11/25 - 22:08
you need to replace sensors.rk29board.so in system/lib/hw .. your can get from a previous rom you
know that works.. or you could try using the fixes from the sam site as rom . or here sensors.rk29board.so
Scap
2013/11/26 - 22:04
Thanks, but it's not working. I copied the sensors.rk29board.so file and I overwrite with the superuser, but the screen rotation still not working properly. Now, if I use the tablet, the screen is rotate upside down :) and still not working if I rotate two vertical position.
In the first post Lolloarnova wrote that:
lolloarnova said
I paused the multiwindows version, less memory free, on Arnova 10g2 have vey low memory available.... about 50/60 mega free.... is too low for daily use.... i publish it in a second moment.
I decided to publish 4.2.2 version AOSP ported from OMA e Challenger.
* I fix Screen Rotation now work fine
* Wifi work fine
* I fix Camera bug, now work fine
Cheers
He wrote: Fix screen rotation now work fine. Do it firmware version work on Arnova 10 G2? and how to download and install it?
Please help me somebody, because I'm starting go to crazy. Thx
petucker
2013/12/08 - 16:01
Would like to know when you get these problems worked out because I would like to increase the ram on my arnova 10g2 to 2 gb.  I have been successful increasing it to 1gb which is a big help for installing apks, be 2 would be great. Thanks for all the work you guys do because this is way before me.
173 Guest(s)
Devices in use: Desktop (160), Phone (12), Tablet (1)
pinsky
louinsky
Arhreanymator
Bestmengqin
jr120065
Mark Naficy
