[ ROM ] Arnova 10 G2 Android 4.2.2 custom firmware (AOSP 4.2.2_r1 Test Build v1.3) with root and Google Play Store
Thanks Received: 3177
2013/08/21 - 13:14
Here is a first test version of a custom Android 4.2.2 Jelly Bean for the Arnova 10 G2.
It is fully based on Crew RKTablets RK29 AOSP 4.2.2_r1 Test Build v1.3
 ARNOVA_10G2_Android_422_OMAv1_3_JellyBean.pngImage Enlarger
ARNOVA_10G2_Android_422_OMAv1_3_about.pngImage Enlarger
This rooted custom firmware features:
  • Android AOSP 4.2.2 Jelly Bean
  • root with latest SuperSU 1.51 (free version)
  • system default setup to English language
  • Google Play Store fixes so more applications are visible/compatible
  • removed all non Google apps, they can later be installed from Google Play Store
  • storage for applications (/data partition) size increased to 2 GB
  • changed screen density to 120
 ARNOVA_10G2_Android_422_OMAv1_3_2GB_apps.pngImage Enlarger
I haven't fully tested the firmware yet, so far I have noted the following problems:
- Camera display is upside down
- some lag and position problems with the accelerometer, needs to have a closer look at those suggestions
- occasional WiFI drops
We are releasing this build for users to test and report problems. Updates and fixes will eventually be done, as time permits.
Download:  kasty_oma_rk29aosp422r1buildv13-arn10g2-422-068-2G.zip
Huge thanks to Oma7144, netlars, Ukrainen, Astralix, JochenKauz, fr3ts0n (Crew RKTablets) for their amazing work!
propprop, jsgage, x.zowie
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/08/21 - 23:07
I paused the multiwindows version, less memory free, on Arnova 10g2 have vey low memory available.... about 50/60 mega free.... is too low for daily use.... i publish it in a second moment.
I decided to publish 4.2.2 version AOSP ported from OMA e Challenger.
* I fix Screen Rotation now work fine
* Wifi work fine
* I fix Camera bug, now work fine
Cheers
The following users say thank you to lolloarnova for this useful post:
ccrrpp, x.zowie
kikias58
2013/08/22 - 14:02
Helle how to download the version lolloarnova ?
kikias58
2013/08/22 - 21:55
Hello I have to install(settle) 4.2.2 he(it) have really very well, beautiful work meme if he(it) recognized it nexus
- Young, not of icone volume Icone
- No calibration of the screen
- Notifications impossible deleted(eliminated)
- Ram from time to time
lolloarnova
ROME - ITALY
Forum Posts: 94
Thanks Received: 32
2013/08/22 - 23:55
If you want try also my rom: http://www.arctablet.com/blog/forum/arnova-10-g2-general/arnova-10g2-lollobean-the-final-jb-4-2-2-aosp/#p28493
Bye.
x.zowie
yojone
Forum Posts: 26
2013/08/23 - 22:56
good as you walk lolloarnova
such this rom, with errors
you get your one
thanks
TTTD
2013/09/24 - 11:30
Hi all,
I  install successfully this custom Android 4.2.2 Jelly Bean for the Arnova 10 G2 but I have a trouble that  couldn't touch screen anything in area  in status bar.  I can uses mouse USB to click on status bar.
Anyone have meet this problems and how do i config touch areas ?
Tks.
mike1000
2013/10/08 - 08:27
hello,
would the image on the 10b g2 run with a resistive screen when you include the driver for the display?
mike1000
2013/10/08 - 09:13
mike1000,
Unfortunately it does not work with external drivers as in Windows or other operating systems, you need a specific Linux Kernel built with support for the resistive touchscreen, which I think is currently not available for your Arnova 10bG2.
Regards.
mike1000
2013/10/08 - 09:55
Thanks for the answer.
mike1000
petucker
2013/10/15 - 03:20
Well, I finally got everything installed but the camera picture is upside down. What do I do to correct that?
Pat
2013/10/15 - 10:14
It's a known bug, see post #1. Unfortunately no fix available at the moment.
petucker
2013/10/15 - 14:54
Besides camera screen being upside down, the device rotated backwards. If I turned it landscape, it went portrait. If I turned it portrait, it went landscape. I went back to Finless 1.5. I liked the idea of getting one extra gb for RAM, but too many other issues. Will just settle for the 1gb of RAM I get using Finless 1.5.. If anyone knows of another way to get that extra gb of RAM, please let me. Makes it much easier to add extra apps.
Thanks Received: 268
2013/10/15 - 18:16
That one extra 1gb ram is virtual ram (zram), and is like 10 times slower than the actual 1gb ram. (This is on sequential access), and around 100.000 times slower in random access computations.
Me, i do prefer to have the real thing rather than a gimmick.
Scap
2013/11/24 - 16:27
Hi
I use this firmware and works fine, but I have a problem. The screen rotation is not working properly. Something solution? PLs Help me! THx
Currently Online: desluk
82 Guest(s)
2 Guest(s)
Devices in use: Desktop (77), Phone (6)
desluk
cimoral
merlin077
nrod
midnight-gr
Pajaro047
