arabic lang support on Arnova 10 G2
rakana
2011/12/22 - 21:34
hi guys, plz I want to add arabic langauge to my arnova 10 g2, but I dont know how, plz can anyone help me??
thanks all
Thanks Received: 3171
2011/12/23 - 22:21
If Arabic language isn't listed in Settings / Language & keyboard settings, there is currently no support for it.
Arnova may implement it at a later time, if that does not happen, you may count on independent Cyanogenmod 7 ports, that should be released in the coming weeks.
Fatal
2012/01/02 - 01:38
Hi there , i see this is the only post about this problem. I just updated my AN10G2 with the latest update 20111010 (i think its the right order) and i figured that would fix my problem with writing in arabic but it didnt. the previous GB version also had arabic in the language settings but the letters are seperated and it writes from left to write , those 2 problems make the arabic language pack useless because arabic is writen from right to left and the words have to be connected. i tried installing an arabic keyboard from the market but that didnt connect the letters , solving the problem with the disconnected letters would be a real life saver!
any ideas guys? i really need to fix this. please if you have an idea post it here , if i end up fixing it i will report back for sure.
Thank you
93 Guest(s)
Devices in use: Desktop (77), Phone (16)
heftpflaster
rk.13
