.android_secure folder
masarada
Forum Posts: 18
2012/01/27 - 14:18
Hi all
I can see plenty of asec files in this folder , and some of them quiet hefty too...18 megs etc.
what are these files, and any harm if I take these out [ delete them ]. (would I be then also automatically deleting the aps ? ) ?
TIA
drchips42
Forum Posts: 38
2012/01/27 - 15:57
Going on the work ivedone on my desire , I dont think you can delete them , and even if you did , I dont think it does much.
I think is=t's  part of the OS , which has defined size.
Best bet would be to put a new rom on ...
Maybe wrong..
HTC Desire CM7.1, Arnova 10G2 ( stock rom ) All Google products fully working!!
simondo
Forum Posts: 78
2012/01/27 - 17:11
masarada said
Hi all
TIA
That was hefty maybe 10 years ago now a days its nothing
masarada
Forum Posts: 18
2012/01/28 - 18:56
ummm..judging by the fact that only a measely 256 mb is made available [ the other half is for android] , a few megs here n there can make a difference if one could install a app or not 🙂
85 Guest(s)
Devices in use: Desktop (72), Phone (13)
swan12
heftpflaster
