Android Market Version 3.1.3 100% Working !!!!!! on unrooted device
luciegoose
46
2012/01/23 - 18:34
will this work on arnova 7c g2?
paul
Forum Posts: 18
47
2012/01/24 - 12:16
it worked for me thank you GerrySmile, very clear instructions Smile
gerry
Forum Posts: 71
48
2012/01/24 - 12:19
as far as in know yes it will
oliman
49
2012/01/24 - 17:08
hi gerry , i pm´d you a week ago, i still cant get this to work, followed your instructions to the t but no luck, i have maps and the app icons for everything else , and followed you steps but it wont connect, i have not added any updates since purchase, may this help? also if not if i reset it (the button on side you have to push with the pin will it be the same as when i first bought it?  i am thinking i may have downloaded something else and this is stopping it from working, any ideas would be great, thanks
p.s i have signed in then cleared data, turned off tried again but no luck
gaziz45
50
2012/02/17 - 12:43
hi guys,
7c boy here, followed the instructions and gmail and maps work fine, tried both versions of market 3.1.3 just wont open with a force close. 3.4.4 opens and i can browse and select for download (tried both update to installed app and getting new app) then when i accept the conditions i get a force close....aaaargh so close, so close and yet so farrrr...lol
any ideas?
cheers
gary
Thanks Received: 3171
51
2012/02/17 - 12:46
gaziz45 said
hi guys,
any ideas?
cheers
gary
If you have a 7c G2, I suggest that you check the dedicated subforum:
http://www.arctablet.com/blog/forum/arnova-7c-g2/
It contains two great firmwares that requires a bit of effort to flash, but it's definitely worth it.
gaziz45
52
2012/02/17 - 20:48
thanx, i was just reading them....duh read the whole thing b4 posting blind....lol
gary
4nd
Forum Posts: 28
53
2012/04/21 - 09:30
Has anyone successfully done this on ICS?  I've ordered the Arnova 9 G3 and am just wondering if it has any chance of working.
Thanks Received: 264
54
2012/04/21 - 11:08
Mate your really don`t want to understand 🙂
You, and another guy from the forum have at this moment the arnova 9 g3, wait for some weeks to pass and this way more people buys the device, and someone dumps the rom, and maybe a rooting method will appear, also the gapps problem it should be solved.
Us the 7c g2 users we waited 2 to 6 months to have market on our tablets.
If you will need certain apps, make a list and i will download them for you.
Jay
55
2012/05/03 - 15:43
I have finless rooted firmware (10 G2) but I'm considering going back to stock firmware and using this method to hopefully get certain games to play correctly. (Where's My Water, for one!)  Will this method improve my odds of applications running correctly?
Second question - From a different instruction thread I have modified the files on the 10g2 to make a transparent toolbar because the Kindle application has the first line of every page blocked by it.  If I go back to stock firmware and use this method, will I lose the transparent top bar?
Any advice is appreciated.
102 Guest(s)
Devices in use: Desktop (90), Phone (12)
heftpflaster
rk.13
