Android Market Version 3.1.3 100% Working !!!!!! on unrooted device
drchips42
Forum Posts: 38
31
2012/01/18 - 16:55
3.4.4 on there !! works like a charm !!!!!!!!!!!!!!!!!1 thanks you very much!!!!!!!
HTC Desire CM7.1, Arnova 10G2 ( stock rom ) All Google products fully working!!
oliman
32
2012/01/18 - 19:13
ok it looks like it has worked(using gerrys instructions from 2012/01/18/   16.12) but it is asking me to set up a google account, i enter my username and password but it displays a message saying "your phone needs to communicate with google servers to set up your account, this may take 5 mins" then it says it "cant establish a reliable data connection to the server,, this could be a temporary problem or your phone may not be provisioned for data services" , well i am using the tablet so its not a phone is this my internet connection or were these the stages everyome else went through?
also 2 things please, in step 6 gerry syas pick from 3.4.4 market install market etc or 3.1.2 market install market etc, well both these options displayed so which one do i pick?
also after all that it said do you want to start with setup or launcher?
gerry
Forum Posts: 71
33
2012/01/18 - 19:40
oliman said
ok it looks like it has worked but it is asking me to set up a google account, i enter my username and password but it displays a message saying "your phone needs to communicate with google servers to set up your account, this may take 5 mins" then it says it "cant establish a reliable data connection to the server,, this could be a temporary problem or your phone may not be provisioned for data services" , well i am using the tablet so its not a phone is this my internet connection or were these the stages everyome else went through?
go into settings and manage apps.  Click on Google framework.  Clear the cache files.
Do the same thing for Gmail and clear the cache.
Power down and back up.
DONT launch the market but launch Gmail and login.  It should work.
Now you can launch the Market.
cirrus
Forum Posts: 37
34
2012/01/19 - 12:54
3.4.4 went right on top for me using above method for 3.1.3 , just install the 3.4.4 vending .apk it should update.
lynnspiller7
Forum Posts: 22
35
2012/01/19 - 22:04
Hi gerry,
Thanks for the link you put up, it won't load the page, have truest yesterday and today? Xx
gerry
Forum Posts: 71
36
2012/01/19 - 22:08
megaupload has been shut down please use these files http://www.mediafire.com/?iu9scb6nn302tkr
lynnspiller7
Forum Posts: 22
37
2012/01/20 - 12:22
hi gerry,
i have downloaded the files from your link, i have tried installing them through es file explorer and file expert but it says its downloading and then comes up with with the following message " is has a tick next to it but says application not installed"?
defo testing my persistance lol
lynnspiller7
Forum Posts: 22
38
2012/01/20 - 12:35
update to post 37 - it installs all of the apks except the google services framework
gerry
Forum Posts: 71
39
2012/01/20 - 17:11
hmmm i wonder why ?
did you install in the correct order?
follow the video and instructions from here
http://www.arctablet.com/blog/forum/arnova-10-g2-general/video-google-apps-and-android-market-install-guide/
lynnspiller7
Forum Posts: 22
40
2012/01/20 - 21:06
Hi gerry
I followed the instructions and correct order and the.framework. one still comes up as not installed
Any ideas....
gerry
Forum Posts: 71
41
2012/01/20 - 21:29
http://www.mediafire.com/?19n79m81o51tpht framework.apk
you shouldn't have any probs with framework as it a standard file for all android devices but try that file above insted of the one in my file
lynnspiller7
Forum Posts: 22
42
2012/01/20 - 21:52
Just thort, does it make any difference that I rooted (rumored)
gerry
Forum Posts: 71
43
2012/01/20 - 21:56
hmmm dunno as am on stock ,Pm Finless he should have an answer as he's the root Master
amrsadi
Forum Posts: 19
44
2012/01/21 - 21:06
this is what i did :
on my pc : i downloaded the zip file , then i uploaded it to ' dropbox '
i went to dropbox on my tablet , and using androzip i extracted them to the sd card ,then i installed ' vending  ... apk '
i found  the app store on the front page , and when i wanted to access the store , a message appeared telling my that  'you need to add an account to the device ,do you want to add now ? '
if i choose yes or no , the store will force me to go out to the front page ...
amrsadi
Forum Posts: 19
45
2012/01/21 - 21:53
ok it works now 😀
thx veeeeeeeeeeery much ..
Currently Online: swan12
74 Guest(s)
Devices in use: Desktop (69), Phone (6)
swan12
heftpflaster
