Android Market Version 3.1.3 100% Working !!!!!! on unrooted device
gerry
Forum Posts: 71
2012/01/13 - 22:37
after my epic fail of a thread see here :/blog/forum/arnova-10-g2-general/android-market-version-3-4-4-100-working/
I went back to the drawing board and downloaded every android market out after 1.82 and slowly went through the same process of elimination every time i had a f/c issue with every market i loaded, Until 3.1.3 loaded open up perfectly, i tried downloading an app and bingo it worked to then all my other apps started updating here is the link for you guys to try ,This has not been tried on a rooted device as mine is stock
 http://www.megaupload.com/?d=HMW9AOJK
fingers crossed it works for you as this was many hours of pulling my hair out
i also posted a video here so you can see for yourself
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/13 - 22:54
Gerry well done for your persistence with this.
I cant really test it myself as I have tablet with the Finless latest root with latest Market.
But compared to the Old market that you got previously from a post a few months ago it is a major improvement, so well done. Smile
P.S Great to see users putting Video tutorials up
yanael
2012/01/13 - 23:07
alright work perfectly for me thanks.....
damo
Forum Posts: 243
2012/01/13 - 23:10
Are you original firmware or Bob Finless root ?
yanael
2012/01/13 - 23:20
original firmware 🙂
damo
Forum Posts: 243
2012/01/13 - 23:32
Great news.
Just test it out please if you can by buying an app, checking that downloaded apps show up in the my apps section of the market settings Etc. Can you report back to the forum and if all well I will pin the topic so it stays near the top.
gerry
Forum Posts: 71
2012/01/13 - 23:50
damo said
Great news.
tested it to destruction all apps show in my apps and update accordingly as for buying apps take you through the buy process easily and quickly no problems
Gerry
PhantomUK
2012/01/14 - 16:21
Hi guys,
I'm new to this forum as I've just bought myself one of the Arnova 10 G2's.  I've found this website extremely helpful in setting up my Arnova, and thanks to this thread have now got Android Market 3.1.3 working nicely.  However, I didn't quite manage to get to it the same way as gerry did.  Let me explain...
First of all I factory reset the tablet, I re-installed applib and installed arctools. I then loaded it and selected "Default Apps And Market 3.4.4 (Rootless Install)".  It installed with no problems, I then re-booted the tablet and clicked gmail, then was able to sign in onto my gmail account successfully via wifi.  However, after that, I kept getting a force close on gmail and talk, so I used the gmail and talk files from ultimodiablo's download http://www.megaupload.com/?d=QSM6ATPB which installed and finally worked.  Then to finish off, I downloaded and transfered gerry's vending-3.1.3-signed.apk from http://www.megaupload.com/?d=HMW9AOJK and I now have a working Android Market.  I've now downloaded, updated, and used several apps with no prob's.
Sorry for the long winded explanation, but I hope I've explained it well enough to help.  Perhaps it's a fluke I don't know, but I'm happy with the end result.
cirrus
Forum Posts: 37
2012/01/14 - 19:39
worked for me , thanks , latest market on my 10 G2 (stock) thanks gerry +1
klaus357
2012/01/15 - 11:07
Hi all
i am new and i am from italy: nice to meet you!
SO, i am here to ask how to put on market on my arnova 10 g2
I have an arnova 10g2 with no root, no rom nothing: exactly with the original firmware.
Can anyone help me pls step by step how to install market on my tablet?
thanks in advance
carter67
2012/01/15 - 21:28
Gerry thanks for this post pal...Getting the market on my tablet has been driving me nuts but after downloading and using the app I've finally got the market.
Mate if your ever up in Aberdeen geeza shout and I'll buy you a pint tae say thanks.
Cheers Steve
damo
Forum Posts: 243
2012/01/15 - 21:41
klaus357 said
Hi all
thanks in advance
Please read the posts this is explained in very good detail.
Harry Ola
2012/01/16 - 08:25
Installed 3.4.4 yesterday from the other thread. I am posting in here only to say that when I tried to install the other files (google framework etc) from the link in this thread, it complained about a parsing problem. I had to use the .apks from the other thread by ultimodiablo. Then I ran the 3.4.4 upload from gerry's other thread.
damo
Forum Posts: 243
2012/01/16 - 09:08
For some reason sometimes you get parsing error if you
Have unzipped the files on your device. Try to unzip the file
On your pc and than transfer them to your tablet to install.
Harry Ola
2012/01/16 - 09:23
To be honest, I did not know you could unzip them on the device, so I had already done it on the PC. Embarassed
I wonder if with one set of files I copied them directly to the memory card and the second time round I moved them through the USB cable. Could that have made a difference.
89 Guest(s)
Devices in use: Desktop (73), Phone (16)
heftpflaster
rk.13
