Accounts and sync
damo
Kingston upon hull, UK
Forum Posts: 243
2011/12/27 - 23:51
I was just wondering if there is a way to have the ACCOUNTS & SYNC setting included on the Arnova 10G2 tablet so it is easier to add accounts, remove accounts and change sync settings? or is this something that is specific to Android Gingerbread on tablets not having that in the settings?
I have this setting on my Xperia Android phone and is really useful. Or is this something that would have to be written into the firmware?
Maybe you could answer this one Bob...
dwl99
Forum Posts: 29
2011/12/28 - 08:50
You can use an app called anycut to create a shortcut to accounts & sync.
damo
Forum Posts: 243
2011/12/28 - 11:05
The problem is those settings don't exist on the arnova 10g2
So if it only creates a link than it won't workCry
dwl99
Forum Posts: 29
2011/12/28 - 11:35
Well that's strange cos it worked on the 2 Arnova 10 G2s I tried it on 🙂
damo
Forum Posts: 243
2011/12/28 - 12:08
Thanks I will try that later and glad there seems to be a part solutionSmile
damo
Forum Posts: 243
2011/12/28 - 12:56
Brilliant installed it and you get those settings in a shortcut but how bizarre
That those settings are not accessible through the main
Settings. Anyway great contribution Smile
kaymado
2011/12/28 - 12:57
dwl99 thanks pal, that is a great tip!
I can confirm it works!
drchips42
Forum Posts: 38
2012/01/20 - 11:12
Yup , syncs all Google stuff BAR Calender !!!!!!!!!!!!! grrr
HTC Desire CM7.1, Arnova 10G2 ( stock rom ) All Google products fully working!!
89 Guest(s)
Devices in use: Desktop (79), Phone (10)
swan12
heftpflaster
