10G2 to TV
masarada
Forum Posts: 18
2012/01/17 - 15:39
Is there a way to connect archos 10 g2 to a tv? It does not have a hdmi… does it has other ways to connect to a tv?
My sony tv recognizes my home PC[ via wireless ] and I can play video files on my TV which physically reside on the PC. How can I connect or make the TV see the tablet wirelessly. ?
Thanks in advance
gerry
Forum Posts: 71
2012/01/17 - 16:04
masarada said
Thanks in advance
Hey Mas
I no you can't connect it to tv though a cabled option and as far as know i can do it through network via twonkey , they have Twonkey Beam Browser (stream videos from the net ie youtube ) ,Twonky Mobile (Stream files from your mobile ) both work great on my Panasonic Viera GT30 Series with no problem
masarada
Forum Posts: 18
2012/01/17 - 23:39
Hi Gerry
Thx. for the post.
I can't see any twonky in the 'free' or paid applications on the 10G2.[ because Twonkey advise is 'To download Twonky apps onto your Android device, go to the Market application on your phone and search for Twonky.'
so I am back to sqaure 1. or ......Embarassed
basically all I want to achieve is : play the avi or mkv file on my G2 , but watch it on the Telly[DLNA/UPnP device] big screenWink
masarada
Forum Posts: 18
2012/01/18 - 00:36
I did download the ShareMe Free aps from the store and my TV picks it up. it picks up the video file on the 10G2 but cant play it (codec incompatible), that's the primary reason why I wanted to play it on the G2 and then get it relayed to the TV. tall order...I suppose.
gerry
Forum Posts: 71
2012/01/18 - 00:42
ill get you the twonky free apk so you can side load them
masarada
Forum Posts: 18
2012/01/18 - 16:43
just for the interested, reply from the Tech. Sup.
++++++snip++++++
 Dear Customer,
Your device has not a TV out slot and can not share the media files using wireless connection.
Kind Regards,
Arnova Technical Support
Thank you for choosing Arnova products.
We also have at your disposal on our website, FAQ's, firmwares and drivers.
Feel free to visit our it at website : http://arnovatech.com/change_country.html?country=zz&lang=en
+++++end snip++++++
@Gerry
...was just wondering what would be 'twonky free apk so you can side load them '
- do I go the market place
or
- would it be a mail attachment
or
- would it be a file on this forum
Laugh
gerry
Forum Posts: 71
2012/01/20 - 11:05
it you search twonky on the market youll find twonky mobile (free Trail) and twonky beam browser (free)
91 Guest(s)
Devices in use: Desktop (82), Phone (9)
swan12
heftpflaster
