request for wifi n protocol
rob
2012/09/25 - 20:41
hi guys, newbie here. after much browsing i believe i have uncovered a minor flaw which is currently disabling my wifi on my newly bought arnova 10 g2. basically it will not connect to new sky router as its an n protocol rather than b/g.
can anyone advise the best course of action. tablet connects ok to internet in a friends virgin cable household presumably on b/g protocol.
will there ever be a firmware update/modification which addresses this problem.
Thanks Received: 3169
2012/09/25 - 20:49
I wouldn't put much hope in any firmware update from Arnova on the 10 G2, they haven't published anything since a long time.
I don't think it's even possible to add 802.11n in software (understand thru a firmware update), so the best option is probably try to get your router running 802.11 b/g or connect to one that supports it.
Thanks Received: 264
2012/09/25 - 20:51
activate from your router also the g standard from the settings (1 minute maximum)
you have the username and pass on the back of the virgin superhub
you can not transform a network card that has only the g standard in a N one
Currently Online: xxy444765344, RobertoMelilla
113 Guest(s)
Devices in use: Desktop (110), Phone (5)
RobertoMelilla
xxy444765344
getetdtd
idol2000
yabiyacob
Nafogou80
