Modifying the Arnova 10 G2 custom firmware
finless
Stanton, Ca
Forum Posts: 604
76
2012/01/11 - 17:03
Update.  I tried 0x00200000 and it worked.  I now have a gig of system space.  I thought this was RAM but apparently not as it does work.  One thing I learned is it has to be setup in even numbered 4096 boundries or it wont boot.
Bob
damo
Kingston upon hull, UK
Forum Posts: 243
77
2012/01/11 - 17:18
Great bob.
Have you got that in the form of a new Rom and
I will do some testing with it.
Smile
finless
Stanton, Ca
Forum Posts: 604
78
2012/01/11 - 17:26
It's an updated parameter file but in order to make it work you have to full flash thus erasing everything.
If your OK with that I can post up the new parameter file.  You replace the parameter file in my current ROM kit and reflash everything (not just the parameter file).
Bob
damo
Forum Posts: 243
79
2012/01/11 - 17:32
Please bob.
I am using v1.2 so I will just replace the boot
Image with you new one. I'm so used to flashing
Now everything is backed up and ready
To rumble Smile
finless
Stanton, Ca
Forum Posts: 604
80
2012/01/11 - 17:36
Sorry I meant parameter file not boot.img.
So you can keep your boot screen 🙂
Here is the new parameter file.  Again replace the file in my current ROM with this parameter file and reflash all check boxes except backup.  Also for you damo, use the last boot.img I emailed you with your custom boot screen.
http://www.helifreakswag.com/parameter.zip
Bob
finless
Stanton, Ca
Forum Posts: 604
81
2012/01/11 - 17:40
Also remember to eraseIDB or the changes wont take.
Bob
damo
Forum Posts: 243
82
2012/01/11 - 17:44
Cheers bob I will.
Would be great to see that script you mentioned
For easy boot image creation. I sent you a couple more
As well that I had mocked up but to save you time a way to
Do it ourselves would Smilebe good.
finless
Stanton, Ca
Forum Posts: 604
83
2012/01/11 - 17:51
Damo, also please let me know if you notice this.  As you know the more apps you install the longer it takes to boot up from a cold power off.  However with 1g space I think I gained about 1 minute in boot time.
I did not time this to be sure but it use to take about 5 minutes to boot up with about 100 apps installed.  Now it booted in about 4.  However again I am not 100% sure since I did not time it but to me it seemed a little faster.
Bob
finless
Stanton, Ca
Forum Posts: 604
84
2012/01/11 - 18:04
Damo, do you have linux?  If so I can easily tell you how to unpack boot.img, convert a .png to .rle, and repack boot.img.
It's pretty easy to do but you need both a windows environment and a linux environment.
Bob
damo
Forum Posts: 243
85
2012/01/11 - 18:06
I will do Bob, it is 5pm here In England, just wait for my daughter to go to be at 8 and I will start flashing the tablet. I have written down some timings from last time I re flashed your firmware a few days ago, with the programs I had on so I can be quite precise.
Timer to the ready, well soonSmile
damo
Forum Posts: 243
86
2012/01/11 - 18:07
Bob
Yes I have Ubuntu, so that would be great Bob.
finless
Stanton, Ca
Forum Posts: 604
87
2012/01/11 - 18:13
I will make a new post on how to make your own boot screen.  Stay tuned.
Bob
damo
Forum Posts: 243
88
2012/01/11 - 23:56
Bob
I will get back to you on this Bob at the minute I cannot get the Market to connect to the Google Server the message cant establish a reliable data connection, re flashed twice now
finless
Stanton, Ca
Forum Posts: 604
89
2012/01/11 - 23:59
Hmmmm..... Admin had me add a line in my lastest init.rc to write a ID to the IMEI file.  If you still cant get it going I will make a new one with that removed.
Don't spend too much time on getting it to work!  Let me know after a couple attempts if you cant and I will give you a new boot.img
Bob
damo
Forum Posts: 243
90
2012/01/12 - 00:02
flashed 3 times now Bob
Tried all the generic clearing cache etc...
still no luck
Currently Online: antoniors021
63 Guest(s)
Devices in use: Desktop (54), Phone (10)
antoniors021
wemiy54158
sidor
houssmen
qarolus
dav512
