Custom firmware for the Arnova 10 G2 (v1.2) *development only*
onericardo
Forum Posts: 13
46
2012/02/02 - 01:59
finless said
My latest 1.3 ROM is out.  Just google it.
I have not been slacking off... Just working on tuneing my ROM.  This one is reported by users is way faster!  🙂
Bob
" Just gogle it ". It's wasn't easy to find your 1.3 version but after some search I found it.
Excellent Rom so far. Have the " limited app " problem but the fix solved it.
This is kind of a request.. Don't you think that the Circle Mod battery would be usefull ? Can you add it ?
Thanks.
oldduck
Forum Posts: 21
47
2012/02/02 - 03:38
Bob
Just downloaded and installed the version 1.3, so far so good only with minor uncertain problem:
1. After flashing the Arnova, initially the boot up time was really fast when nothing installed yet.
2. Realized the Market not showing all searched apps issue, then following instruction to remove the data.dat and those com.android.xxx folders, issued solved.
3. After restoring the apps by using Titanium Backup, now have 72 user apps and 51 system data reported by Titanium, but the boot up time becomes 4 minutes 30 seconds! Not sure whether the long boot up time is caused by lots of apps installed or due to removing the data.dat file, as in 1.1 ROM, the boot up time was around 2 minutes I guess.
finless
Stanton, Ca
Forum Posts: 604
48
2012/02/02 - 04:13
I cant fix the boot time.  Thats inherent with this version of android.  The more apps you add the longer the boot as more stuff has to be copied to RAM, etc.
Bob
105 Guest(s)
Devices in use: Desktop (94), Phone (10), Tablet (1)
roroL14
rodrigo14
gerry3818
jaga1986
Piotrassss
mgsppt
