Creation of a firmware-based CyanogenMod 7
Morka
Lille
Forum Posts: 203
Thanks Received: 75
2012/01/19 - 19:02
1 have the original firmware (for extraction update.img)
2 download the file http://files.androtab.info/rk2918/cm7/20111126/boot.img
3 download file rockdev inclue RK29xxImageTools_v2.1 (for extract update.img), rockdev (RK2918 SDK for build update.img), Rockchip_Batch_Tool_v1.4 and Rockusb usb drivers
Before any installation
Fixed sound and wifi by copying the file for your version before instalation CyanogenMod
copy with es file explorer
rk2918/system/etc/rockchip_bq27510.bqfs
rk2918/system/etc/rockchip_bq27510.dffs
rk2918/system/etc/firmware/athtcmd_ram.bin
rk2918/system/etc/firmware/athwlan.bin.z77
rk2918/system/etc/firmware/calData_ar6102_15dBm.bin
rk2918/system/etc/firmware/data.patch.hw2_0.bin
rk2918/system/etc/firmware/device.bin
rk2918/system/etc/firmware/fw_bcm4329.bin
rk2918/system/etc/firmware/fw_bcm4329_apsta.bin
rk2918/system/etc/firmware/nvram_B23.txt
rk2918/system/etc/firmware/sd8686.bin
rk2918/system/etc/firmware/sd8686_helper.bin
rk2918/system/etc/firmware/softmac
rk2918/system/lib/libaudio.so
rk2918/system/lib/libaudiopolicy.so
rk2918/system/lib/libcamera.so
rk2918/system/lib/liba2dp.so
rk2918/system/lib/libjpeghwdec.so
rk2918/system/lib/libjpeghwenc.so
rk2918/system/lib/libvpu.so
rk2918/system/lib/libGAL.so
rk2918/system/lib/libstagefrighthw.so
rk2918/system/lib/egl/egl.cfg
rk2918/system/lib/hw/copybit.rk29board.so
rk2918/system/lib/hw/gralloc.default.so
rk2918/system/lib/hw/gralloc.rk29board.so
rk2918/system/lib/hw/hdmi.rk28board.so
rk2918/system/lib/hw/lights.rk29board.so
rk2918/system/lib/hw/overlay.rk29sdk.so
rk2918/system/lib/hw/sensors.rk29board.so
rk2918/system/lib/modules/wlan.ko
rk2918/rk29xxnand_ko.ko
fix by birdiebnl
_________________________________________________extraction
RK29xxImageTools_v2.1 folder
N° 1 copie original update.img rename wendal.img
N °2 clic Runme.bat follow the instructions to extract
going to be a temp/ folder created
___________________________________________temp folder
Image Enlarger
copy the file in red is put in the folder rockdev/
and
Image Enlarger
copy the file in red is put in the folder rockdev/image and file http://files.androtab.info/rk2918/cm7/20111126/boot.img
______________________________________________rockdev folder
Image Enlarger
clic mkupdate.bat for build update.img
to flash update.img CyanogenMod 7 use RKBatchTool.exe (RK2918)
/blog/featured/flashing-arnova-g2-rockchip-2918-rockchip-flashing-tool/
Image Enlarger
Image Enlarger
Image Enlarger
Image Enlarger
Here sorry for my english
cneumi
2012/01/24 - 03:18
I've been trying to understand the instructions, but I'm really lost. I'm not a complete newb at this either--been playing with custom ROMs on my phone, and my 10 g2 is running Finless's ROM, but I'm having a lot of trouble following your directions.
Currently Online: xxy444765344, RobertoMelilla
114 Guest(s)
Devices in use: Desktop (112), Phone (3), Tablet (1)
RobertoMelilla
xxy444765344
getetdtd
idol2000
yabiyacob
Nafogou80
