cm7 work.
simondo
Forum Posts: 78
2012/01/05 - 00:15
Im working on cm7.1 for our device ive compiled cm7 before for the lg p500 so i have some experience right now im downloading cyanogen's source code.
Thou any help would be appreciated.
finless
Stanton, Ca
Forum Posts: 604
2012/01/05 - 00:29
I am willing to help in anyway I can!  Not much of a coder anymore but I pick up on things quick so maybe I can do the little chores you may need.
Bob
simondo
Forum Posts: 78
2012/01/05 - 01:05
Thanks but my internet has gone down half way throu downloading the Source.
Im on my mobile right now. I aint much of a coder ether as most of the work on my lg p500 was already done i just compiled and tweaked it never did bother releasing what i did.
I know i little but of coding. And how to compile things i can fix most compiling errors and im a quickish learner
p1ceus
Forum Posts: 38
2012/01/05 - 08:49
Hello simondo,
I'm willing to help you too if you want, I set-up my Ubuntu VM few day ago and after some errors with CM9 compilation, I moved to CM7 to gain some experience first.
P.S. I synchronized this git repository and pull all required files from our tablet already, so I can provide them to you if you want.
simondo
Forum Posts: 78
2012/01/05 - 14:21
Ok thanks just zip all your source code and host the zip somewere
p1ceus
Forum Posts: 38
2012/01/05 - 16:54
Hello simondo, here are the source files. Just copy them to the root of your buld directory (e.g. android/system).
Then just run . build/envsetup.sh and lunch and you should see rk2918 in the list.
simondo
Forum Posts: 78
2012/01/06 - 19:06
Could someone please zip the full CyanogenMod 7.1 or 7.2 Source code as i cant download the git it just freezes half way.
Thanks Received: 3169
2012/01/06 - 19:07
I am not sure which repository you want, can you point me to the right sync address ?
simondo
Forum Posts: 78
2012/01/06 - 23:50
Here it is.
kdir -p ~/bin
curl https://dl-ssl.google.com/dl/googlesource/git-repo/repo > ~/bin/repo
chmod a+x ~/bin/repo
echo $PATH|grep ~/bin>/dev/null||export PATH="${PATH}":~/bin
Then
mkdir -p ~/android/system
cd ~/android/system
repo init -u git://github.com/CyanogenMod/android.git -b gingerbread
repo sync -j8
2012/01/07 - 00:21
The sync has failed with error: Exited sync due to fetch errors, without giving any detail on the error.
Still, I have made an archive for you, not sure if it's usable.
http://www.arctablet.com/users/forum/cm7src.tgz.bz2
I will restart a sync tomorrow, will let you know.
simondo
Forum Posts: 78
2012/01/07 - 01:33
Hmm i dont get any sync errors just freezes and stops downloading.
Ill take a look at the archive but i dont think it'll be usable.
simondo
Forum Posts: 78
2012/01/07 - 01:52
When you resync it use command: repo sync -f
It will force it to finnish even if it fails to download a project.
simondo
Forum Posts: 78
2012/01/07 - 14:40
Hmm that archive's unusable its missing too many key files.
2012/01/07 - 14:41
I have restarted a download with -f, I'll keep the repo output if you want to have a look...
Will post the new archive when ready.
2012/01/07 - 16:08
101 Guest(s)
Devices in use: Desktop (97), Phone (4)
roroL14
rodrigo14
gerry3818
jaga1986
Piotrassss
mgsppt
