A little linux help please (file patching tool needed)
finless
Stanton, Ca
Forum Posts: 604
2012/01/11 - 20:55
OK so I am still a linux n00b here.  I am scripting how to pack and unpack boot.img so people can do their own boot screens or edit things as they see fit.
So here is what I am asking.  Once I gzip up boot.img and add the md5crc with rkcrc, the file has to be editing in a hex editor to change the first 4 bytes from PARM to KRNL or the Arnova will not boot.
Can someone give me the linux shell command to write the first for bytes of boot.img with KRNL overwriting the PARM?
Thanks,
Bob
josbos
Forum Posts: 57
finless
Stanton, Ca
Forum Posts: 604
2012/01/11 - 22:44
What you going to make me work to learn to do it?  😉
I read it but not making much sense... What ia AIX?
Bob
josbos
Forum Posts: 57
2012/01/11 - 23:05
AIX is an IBM linux flavor (it has no graphical interface, everything is command based), I have some customers who run it, they like it, I'm not.
But the shell commands used in the post does work on all linux distro's, also on Ubuntu.
Sorry that I can't give you a working solution, I'm no linux expert either, but the most fun part in "hacking" is learning by trial and error. Unfortunately I'm back at work, so I don't have the time anymore.
What you can try doing in meantime is run the following command in shell:
man od
This will provide you an explanation of the most important command.
If you can wait a few days, I can write you a c program, over the weekend, to make the adjustment.
I also made a custom version of the rkflashtool to strip a dump if it contains trailing blanks at the end to the correct filesize.
finless
Stanton, Ca
Forum Posts: 604
2012/01/11 - 23:13
I am working on a package with scripts to help new guys mod the boot.img.  While a C program is fine I was hoping to update rkcrc.c to make the changes to the file and change PARM rto KRNL.  I am sure it is a simple write command but I do not know how to do it at this time.
Can you possibly download rkcrc.c and make the edits for me to test?
You can download the RK tools from here and edit the rkcrc.c to do it?
https://github.com/naobsd/rkutils
Bob
josbos
Forum Posts: 57
2012/01/11 - 23:14
I have the code already compiled on my ubuntu and will modify it.
Do I add an argument for it? Or do I check on the filename, if it's boot.img always change the param?
simondo
Forum Posts: 78
finless
Stanton, Ca
Forum Posts: 604
2012/01/12 - 00:44
Yes please.....  If you want to add a switch like -rk or something to do the PARM to KRNL that would be GREAT!
Thanks!
Bob
finless
Stanton, Ca
Forum Posts: 604
2012/01/12 - 16:23
simondo said
http://manpages.ubuntu.com/manpages/natty/man1/hexcurse.1.html
This might help
Doesnt help.  It says at the bottom:
TODO When we get the time, we would like to implement the ability to insert
and delete data from the file. Please e-mail us with any additional
suggestions.
 Bob
Thanks Received: 3169
2012/01/12 - 16:31
Thanks,
Bob
I'll let you know if I find something. In the worse case, it will be a matter of just a few lines of C code.
ttz642t
Forum Posts: 53
2012/01/12 - 17:46
See my posts in:
http://www.arctablet.com/blog/forum/arnova-10-g2-development-forum/arnova-10-g2-custom-rom-development-with-linux/#p2808
The rkcrc command can recreate the boot.img perfectly, no C to do.
I started the thread to hopefully get various toos contributed for development on Linux, but Ive had little time.
Your rom has been a good one to start work on.
I've started a wiki, I hate forums, thousands of posting to collect all needed info.
Currently Online: xxy444765344, RobertoMelilla
114 Guest(s)
Devices in use: Desktop (112), Phone (3), Tablet (1)
RobertoMelilla
xxy444765344
getetdtd
idol2000
yabiyacob
Nafogou80
