reliable hard case?
register
Forum Posts: 84
2012/02/11 - 00:39
given the reports from users having their screens accidentally broken - what would be a reliable hard case that would fit the arnova 10g2?
damo
Kingston upon hull, UK
Forum Posts: 243
2012/02/11 - 09:18
Please see this link
http://www.arctablet.com/blog/forum/arnova-10-g2-accessories/case-for-arnova-10-g2/
I have the tuff case mentione and it is very good and
Fits perfectly
register
Forum Posts: 84
2012/02/11 - 10:14
i saw this but i didnt think its a hard case - just a leather case
how tough is it - can you bend it?
because if you can... well...
the design also does not seem particularly impressive - no offense but looks like a grandpas wallet...
http://tuff-luv.com/media/catalog/product/cache/1/image/500x500/9df78eab33525d08d6e5fb8d27136e95/a/r/archos101_triaxis_black_03_1.jpgImage Enlarger
i was thinking of something along this line
http://www.tablet2cases.com/wp-content/uploads/2011/07/hardtabletcases3.jpgImage Enlarger
http://www.tablet2cases.com/magento/media/catalog/product/c/a/case-mate-kindle-fire-tuxedo-folio-case-in-black-5.jpgImage Enlarger
http://www.tablet2cases.com/magento/media/catalog/product/cache/1/image/646x464/9df78eab33525d08d6e5fb8d27136e95/i/f/ifrogz-ipad-2-summit-case-black.jpgImage Enlarger
http://www.tablet2cases.com/magento/media/catalog/product/d/o/dodocaseblackberryplaybookbookcase13_1.jpgImage Enlarger
damo
Forum Posts: 243
2012/02/11 - 10:37
I see what you mean, the only thing is the one I have is one that stays
On the tablet all the time and it has been specifically designed for that tablet so all
The cut outs etc are in the right place.
If it is just a hard case that you store your tablet it that a generic one
Would work. But for me it is more important to protect the
Tablet when using it as well or a case is useless.
The case would be kind of hard to bend because the tablet is in it.
register
Forum Posts: 84
2012/02/11 - 14:46
im not sure i understand your point - all hard cases allow the use of the tablet
im just looking for a hard case that would fit the weird size of the arnova 10
alex
Forum Posts: 252
2012/02/11 - 14:52
i have this for my 9 g2 qid=1328968204&sr=8-1
its not designed for it beacause i couldnt find a 9" tablet keybard case i suppose it would fit the 10g2 perfectly the keyboard makes it practical 😉
register
Forum Posts: 84
2012/02/11 - 15:45
the page says "We have been informed that this case is NOT compatible with Archos Tablets." Surprised
i guess its because of this review
alex
Forum Posts: 252
2012/02/11 - 16:23
its a good job you want it for an arnova then isnt it 😛 im not sure tho you will have to compare where the sockets are in relation to the 101  the only problem with mine is that its too loose as its too narrow but apart from that its fine
Deedee Rose
Forum Posts: 17
2012/02/12 - 11:50
I bought a case designed for the 101 and all the cutouts are in the correct place, so i'd guess any 101 case would do.
I have this one: ie=UTF8&qid=1329043649&sr=1-4 and it works just fine.
klaus357
2012/02/16 - 17:56
i have bought this one
ie=UTF8&qid=1326763010&sr=1-1
it fits perfectly!
all right holes: for the rear speaker too!
one word: PERFECT and by ARCHOS!
Currently Online: chaoiki13
93 Guest(s)
Devices in use: Desktop (83), Phone (10), Tablet (1)
Johann Trouve
MOADITH
jomacupi
michaos113
mamago68
peaches51
