Gamepad controller
mozart321
Forum Posts: 13
2012/01/08 - 15:02
Hi
Has anybody had any luck in getting a gamepad type controller working on the 10 G2? It would be great to be able to play roms.  I'm going to try a couple of different controllers from friends and will update when I do.
Mozart321
drchips42
Forum Posts: 38
2012/01/20 - 15:45
I have tried on a xbox " look " controller, the lights come one , but it will it does not move any thing on the screen , unlike a usb mouse.
The lights on the controller come on , but there is not enough power in the USB port to enable it to work .
However ... you can link a powered USB hub into the tablet ... and that works.. I have not tried a controller though that  ... may try that tonight !!
HTC Desire CM7.1, Arnova 10G2 ( stock rom ) All Google products fully working!!
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/20 - 16:06
That would only work firstly if you had a driver for it and secondly
If the game supported a controller, and since they are designed to
Run on touch screen devices it is not likely that they would build
Any support in for a controller.
mozart321
Forum Posts: 13
2012/01/20 - 16:46
The various emulators have support for bluetooth controllers usually... Although it is obviously an issue without bluetooth on our device..
62 Guest(s)
Devices in use: Desktop (51), Phone (11)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
