2011/12/15
hi
i have just acquired the Arnova 10 G2, and i would like to know if there are any drivers or support that i could install to get the HUAWEI E367 HSPA+ dongle working on it, i have installed the latest update from the Archos website but this has no effect regarding the issue.
i also have an older dongle, the HUAWEI E160G HSDPA, which works without fault on the tablet, but i would really like to get the newer 1 working.
Any help would be greatly appreciated
2011/12/15
I don't own this tablet yet (planning for one), but I guess there's not much you can do assuming you didn't find any drivers. It's already brilliant a 3rd party 3g dongle works with it. Did you install anything or it did automatically ? Did you have to choose any connection or internet just worked ?
If the dongle is supported, it probably behaves like the Archos 3G Stick that you can see here:
/blog/featured/arnova-8-g2-review-3g-support/
(should work the same on Arnova 10 G2)
2011/12/15
thanks will need a micro USB lead in order to try the dongle in that way, i did try the lead that came with the dongle which is a regular USB lead but was still the same result, but i shall keep you posted
with the dongle that works it was just a case of plug n play, it installed itself n connects to the 3G network no problem, but its seriously old n slow, which is why i want the newer one to run
2012/01/02
another option until 3g dongles can be made to work properly is just to tether your tablet to your andriod mobile phone.
wired tether doesnt seem to work but making a virtual wifi spot from your android phone works great, i can now go online away from a wifi spot using my phones data plan.
62 Guest(s)
Devices in use: Desktop (51), Phone (11)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
