Bluetooth USB Key for Arnova 10 G2
Related Tags
fxubmc
Forum Posts: 20
2012/01/02 - 17:26
i have a question for you. Exist an USB Bluetooth Key for Arnova 10 G2?
I think Android 2.3 have drivers for bluetooth but.... i'm not an expert.
Someone want to help me?
Thanks in advance
2012/01/02 - 17:31
There are chances that Bluetooth support has been kept in the kernel/drivers, but I haven't heard about a compatible usb dongle so far.
I tested a Trendnet dongle without success, I hope someone had better luck with another adapter.
finless
Stanton, Ca
Forum Posts: 604
2012/01/02 - 23:13
In my poking around in all the build.prop and init.rc files it sure looks like BT is still in there.  I guess they could have removed them from the Kernal though.
Bob
fxubmc
Forum Posts: 20
2012/01/19 - 08:47
I look the original stock firmware and the update of the october.
In the original stock there was the menues for turnig on Bluetotth, setting it etc etc.
When i update the firmware with the upgrade of october this menu of settings diapparear.
I think the original stock contains more bluetooth elements than the upgrade.
Jean-Luke
2012/01/19 - 09:04
Jean-Luke
Strange, I never had Bluetooth settings in any of the Arnova 10G2 firmwares I downloaded. Can you post a link to the firmware that had it ? This may be worthless as the device is supposed not to have bluetooth hardware... it's probably not just disabled in the software.
fxubmc
Forum Posts: 20
2012/01/20 - 08:43
sorry but is not possible. I don 't download that firmware. When i buy the tablet, it starts in 2 minutes and has that menu "settings -> Connections -> Wireless -> Bluetooth Settings"....
When, in october, i update the firmware with the arnova official firmware update... the time to start increse to 3/4 minutes and the menu of bluetooth vanish!
I've no idea what kind of firmware was because it was preinstalled and the tablet was new (buy at Darty in Milan - Italy).
Bye.
Jean-Luke
fxubmc
Forum Posts: 20
2012/01/20 - 11:25
look at this video
is a bluetooth keyboard but... the tablet used for the test "Dropad A8/Herotab C8" is connected by a Bluetooth pen because it haven't bluetooth!!!!!!!!!!
Look the cable who connect the USB port to the Bluetooth pen from 0:20 to 0:40.
Jean-LukeLaugh
2012/01/20 - 11:37
Thanks for the video, there is some hope by reading this  (Youtube video description)
"be aware that external bluetooth dongle did not work on a Dropad A8 (a.k.a. A8i) with Android 2.2 (factory default). It was needed to update to Android 2.3.1 (build 0531) in order to make bluetooth available* (using the USB Host and a USB bluetooth dongle), which means that some external bluetooth devices can be used on the Dropad A8 tablet, such as Keyboard, GPS and Wiimote."
Let's hope someone can test a similar BT dongle
Bluetooth USB 2.0 Aluminum Dongle
http://www.dealextreme.com/p/bluetooth-usb-2-0-aluminum-dongle-6-device-simultaneous-support-6678
fxubmc
Forum Posts: 20
2012/01/20 - 12:52
Dongle Micro USB Bluetooth for Arnova 10 G2  found?
Look at this link...
http://www.idealo.fr/liste/41074584/dongle-micro-usb-bluetooth-sur-arnova-10-g2.html
Well.... it's a true hope or is a fake?
Jean-Luke
2012/01/20 - 12:58
No idea if it will work, need to try and see, preferably with the same dongle as the on on DX (or dongle using the same chipset)
2012/01/20 - 23:13
It looks like Bluetooth dongle using  Cambridge Silicon Radio (CSR) chipset should be prefered.
http://www.slatedroid.com/topic/18090-haipad-m7-and-usb-bluetooth-dongles/page__view__findpost__p__200507
If anyone want to try any Bluetooth dongle you might have and report here if it's working...
Thanks.
2012/01/26 - 18:33
Thanks.
Nobody has a CSR bluetooth dongle to try ?
simondo
Forum Posts: 78
2012/01/27 - 00:07
Android doesn't natively contain USB bluetooth drivers. So unless archos added it then it wont work.
2012/01/30 - 14:47
Some updates on the subject, fenice57 has made changes on the Arnova 7G2 firmware so it gets partial support of some Bluetooth USB dongles. I will be testing that soon, will report here.
fxubmc
Forum Posts: 20
2012/02/07 - 10:49
Wow! Great! We hope it runs well and made the same changes in Arnova 10 G2 custom firmware.Laugh
150 Guest(s)
Devices in use: Desktop (144), Phone (6)
