Here is a new package that should help fixing the Deep Sleep issue on your Rockchip based devices.  This problem actually affects some 3G enabled tablets that have some problems entering in Deep Sleep mode. This fix was originally posted on 4pda.ru forum.
How does it work ?
The script basically creates a backup file of your existing libril-rk29-dataonly.so in /system/lib directory, the file is named libril-rk29-dataonly.so.backup in case you want to restore it. Then it installs the modified file libril-rk29-dataonly.so.
Requirements and compatibility
A rooted firmware is required, if you are not running one of our Kasty firmwares, you should be able to find one for your device in our forum.
If you are using a different firmware and ArcTools is not pre-installed, you can download it here:
Running the package
- start ArcTools.
- in the package list select: Â "Deep Sleep fix for some Rockchip RK3188 based tablets (libril-rk29-dataonly.so fix from 4pda.ru)"
- click Download button to retrieve the package on your tablet
- once download has finished, please click "Install apps" button to run the installation script
- reboot your tablet
The usual disclaimer applies:Â our application and package come with no warranty for any use; you use it at your own risk.
TecKnight, derricktanyz If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
2012/11/04
Admin,
So this inability to enter "deep sleep" only affects devices that use a 3G modem ?
I don't use 3G at all, so I should not install this ?
I did some googling on this and it seemed to indicate that applying this fix would allow the device to enter deep sleep, but would disable 3G functionality on the device.Here is the post:
I guess my question is, who should install this and will it disable 3G functionality ?
My mistake, the ArcTools package was visible to private testers only and not to everybody, it's fixed now.
From the info I have gathered so far, the fix it interesting mostly for users of 3G tablet, which have problems to enter deep sleep. It may also be interesting for other Rockchip based tablet users having problems with deep sleep, but it's not widely tested so far. It's not a risky procedure as the original libril-rk29-dataonly.so is backed up in case restoring the original file is necessary.
2013/05/25
Samadhan said
need this fix arctools 0.8 dont have this
unzip this file and place in \system\lib. Overwrite the existing .so file. Then reboot i guess.
Cube u30gt2 tab
78 Guest(s)
Devices in use: Desktop (65), Phone (13)
dfrt
PQNY
chema1971
speedyftp
georgicaa97
kkn
