2012/11/04
DroidUserRJC said
I did reflash and got an error when the flash was done and the reboot happened. Seems not to have effected the rest, now on 4.4.1 and the stock recovery.
Is this basically an answer that CWM does not work with the Cube U30GT C4? Although it has a RK3188 chip? It is more or less a special version and not a wide user base, I'm afraid. Can anyone report if they got it working on this specific device?
DroidUserRJC,
Basically, yes. This is an experimental build and while it has been found to work on many RK3066/RK3188 based devices, several have had issues or have not worked altogether. I do not see anyone confirming this build is functioning on a U30GT C4 yet, but I will doublecheck. The messages you are describing sound like your system may not be using standard mount points. Can you get the specific messages that are displaying ?
OK, The following Cube tablets are confirmed to work, but your tablet is not among them:
Cube U30GT (RK3066) tested by admin
Cube U23GTC4-W (RK3188) tested by admin
Cube U30GT2 (RK3188) tested by Sethi, thantos and DaezD, saciorlux and robiom
Cube U39GT tested by manu_katz
A good place to ask would probably be in the forum section where you downloaded the firmware U30GTC4 KitKat firmware.
Edit: I can't check myself, not having an U30GTC4, but I should be able to have a look on my PiPO M9 pro for which I published a custom Android 4.4 KitKat firmware.
2012/11/04
sbr.harry said
ifive x2[ ROM ] FNF iFive X2 Android 4.4.2 KitKat custom rooted firmware based on v2.0.0 (2014/01/08)
Can't mount any patition except external sd.
Can't backup.
Finally, can't reboot.
Thanks sbr.harry,
Actually there is already a modified CWM recovery here:
The following users say thank you to TecKnight for this useful post:
sbr.harryAs TecKnight mentioned, CWM Recovery supporting KitKat devices has been added and post #1 updated.
(edit 2014/01/14) CWM Recovery for Android 4.4.2 KitKat firmware
If you are running an Android 4.4.2 (KitKat) firmware on your Rockchip device, we recommend using this package: "iFive X2 Android 4.4.2 CWM Recovery by ManuPC". Thanks ManuPC for providing this recovery image.
2013/11/16
barumbado1318 said
Hallo, Uhm. I cant create back up via CWM. Im install the Generic one coz i cant find the "iFive X2 Android 4.4.2 CWM Recovery by ManuPC" package for my X2. I hope someone can help me. Thanks in advance
Hi
https://www.dropbox.com/s/3ccpxj0yis97sge/FW%20Tool%20%2B%20CWM%20f%C3%BCr%204.4.2%20KitKat.7z
Uncompress with 7zip/7z only
cheers
The "iFive X2 Android 4.4.2 CWM Recovery by ManuPC" package is now enabled for KitKat firmwares on the iFive X2 (latest from 2014/01/22) and the Cube U30GT2 (2014/01/21) as well.
58 Guest(s)
4 Guest(s)
Devices in use: Desktop (54), Phone (4)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
