ClockworkMod (CWM) Recovery easy install on RK3066 and RK3188 devices
mirabox
61
2013/11/24 - 17:25
thanks for my PIPO M6 !
Works fine.
Mic
jrgalang
Forum Posts: 17
Thanks Received: 6
62
2013/11/25 - 17:55
Works like a charm on U30GT2. Thanks!
Uncle Jed
63
2013/11/26 - 03:02
Thanks, much appreciated!!!
CWM Recovery installed easily on my Pipo Max-M1 with TNT Release 6.
Backup to Internal SD worked on first try, backup to External SD worked after reformatting my SD card to FAT32. (it was NTFS) This also made it possible to access the External SD for all other CWM Recovery functions! Unfortunately this now limits the file size on the External SD to 4 GB. I’m OK with that but if anyone knows of a workaround to keep my SD card NTFS, it would be much appreciated.
Uncle Jed
Ps. make sure to save all your files before formatting!!!
jtheg
64
2013/11/26 - 10:44
Failed to work on my sons 9.7" sumvision titan?  Just got black screen when rebooting after installing recovery?
mrc_o
65
2013/11/28 - 16:35
hi guys, just installed kasty rom, so went to "ARC TOOLS" as in the video..then reboot  and recovery but the tablet stopped with the andorid rotbot with trinagle  says " no command" and i had to do the hard reset!
i have a piop m9 pro 3g.....
what s wrong? do i have to back up something before? i'm confused!
Thanx a lot
66
2013/11/28 - 16:37
mrc_o,
The dead robot means your device is booting the stock recovery, somehow the CWM install did not work on your tablet. Since it's confirmed to work on the PiPO M9 pro, you may want to try again (two more times if needed) to see if it finally works.
mrc_o
67
2013/11/28 - 19:28
thank for reply,
...i won't do it i'm a bit worryed that something can go wrong and i don't wont to brick the tablet!
ps.
i'm new to android but if like windows, do not i need first to make a partition for the recovery? or the process i see in the video create the partition after rebooting?
cheers
The following users say thank you to mrc_o for this useful post:
Reini
smudgered
68
2013/11/29 - 10:58
Did you install the Kasty Rom using ARCTOOLS?
I am unsure myself but I get the impression in the video that ARCTOOLS does everything whereas you imply you only used ARCTOOLS after you had installed Kasty Rom via another method.
Perhaps admin could make clear?
69
2013/11/29 - 11:18
Kasty firmware needs to be installed with Rockchip Batch tool, as stated in each forum post about a custom firmware release.
ArcTools as you see in the video here is used only to add CWM Recovery to an existing rooted firmware (ex. Kasty).
smudgered
70
2013/11/29 - 12:06
Thanks!
This is possibly a silly question(s) but for an existing rooted stock firmware (up and running with data/apps) with no recovery is procedure the same (is it better to start again from scratch i.e. flash rom and then ArcTools CWM install? Also does ArcTools reformat the SDCard when installing CWM?
chr0n1k
71
2013/11/29 - 18:29
Nice job Worked nicely on a L10A1G Stock Rom.
mrc_o
72
2013/11/29 - 21:14
I used the RBTool forma the kasty:-)
mrc_o
73
2013/11/30 - 13:33
mrc_o,
can use titanium backup for recovery? i have the  last kasty installed.
oscarhotel
74
2013/11/30 - 17:11
My tablet is U9GT5 is root.
I installed arctool.
I rebooté with arctool.
I have Android with the triangle, but I cannot which buttons use then.
Cordially.
hal rockwell
75
2013/11/30 - 20:55
Is there a way to revert back from CWM to the original recovery or boot into it?
53 Guest(s)
2 Guest(s)
Devices in use: Desktop (47), Phone (5), Tablet (1)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
