ClockworkMod (CWM) Recovery easy install on RK3066 and RK3188 devices
Balrog
Forum Posts: 48
Thanks Received: 15
31
2013/11/05 - 22:19
Install and runs on Pipo M6 max (internal sd only tested for now).
axelrichter
Forum Posts: 30
32
2013/11/06 - 14:15
Hello everybody, i like your work on any Odys products.
I have the Odys Aviator with a RK3306 Chip  and i hope you make it possible to build a CW10.2 for it.
i hope so,
Thanks for your work.
hedom
33
2013/11/06 - 17:28
A few questions:
With what key combination I can start the recovery m9pro with that?
Can I install a theme CM10/CM9 it? And if so, how?
Can I install the rom KASTY it? And if so, how?
Thank you
Balrog
Forum Posts: 48
Thanks Received: 15
34
2013/11/06 - 20:30
Backup works fine to external sd-card at Pipo M6 max.
Igor101
Forum Posts: 18
35
2013/11/06 - 21:29
The USB on my M9 is dead, so the Rockchip Batch Tool is not an option. I am very keen to discover if there is an alternative way to flash a Kasty ROM using CWM.
Please, can anyone help?
36
2013/11/06 - 21:31
Igor101,
I'm getting my PiPO M9 pro real soon, I should then be able to provide a firmware in CWM format. Just a few days patience and you should be able to try it Wink
Igor101
Forum Posts: 18
37
2013/11/06 - 21:33
That's great, admin.
Many thanks.
vodilo
38
2013/11/10 - 17:57
 не работает выбор в CWM так как нет кнопок громкости на Pipo u 8 :(
как установить CWM touch?
griff2
Sarlat
Forum Posts: 11
Thanks Received: 4
39
2013/11/10 - 23:37
 не работает выбор в CWM так как нет кнопок громкости на Pipo u 8 :( как установить CWM touch?
Используйте левый / правый экран салфетки
flow2013
Lomé-Togo
Forum Posts: 42
Thanks Received: 12
40
2013/11/11 - 12:59
Hi.
 I would like to know what would be the benefit of instaling the CWM on the titanium 70 as there is no custom roms to flash, apart the first and only rooted one.
manu_katz
Créteil (France)
Forum Posts: 19
41
2013/11/11 - 23:27
Installed on Cube U39GT successly.
The first post can be updated to add this devide into the list.
Balrog
Forum Posts: 48
Thanks Received: 15
42
2013/11/12 - 09:10
So I am done with my tests: Pipo M6 max works with backup and restore on internal and external sd-card. Good work! Smile
The following users say thank you to Balrog for this useful post:
vodilo
43
2013/11/12 - 19:00
  Перепробовал все что мне известно,
не работает touch в CWM recovery на моем Pipo u 8Confused
и не видит usb hub! (пробовал разные программы, результат 0!)
ИТОГ: отнес назад в магазин :)
ledba
44
2013/11/13 - 18:33
This is English forum, write in English!
vodilo
45
2013/11/13 - 21:43
ledba: help google translate   http://translate.google.com/
48 Guest(s)
Devices in use: Desktop (44), Phone (4)
yuuma
dima1965
Денисен88
Romanmob
reisender_androit
callmemax
