2016/03/11
it doesn's work for me on a Odys Union 10 with a rooted 4.2.2.
I installed the apk, select the right package, download, install apps, reboot recovery and the screen goes black. Nothin happens.
Then pressed the power button for a few seconds - nothing, then pressed it again and it boot up normaly.
But no CWM recovery.
Do you have any hints for me?
Marcus
OceanBlue72 said
Hello,it doesn's work for me on a Odys Union 10 with a rooted 4.2.2.
Marcus
Nah try this method , the same thing only different method to install. If still cannot then it means that the ODYS has got different partition structure (which I doubt). FYI By the way installing the ArchTools apk only doesnt nearly make it because there is a companion zip file that it comes with in which contains a script file hat is read by the ArchTool.
2016/03/11
Thanks for your reply!
Which different method do you mean?
The download only contains an apk file. There were no seperate zip file. After pressing install it shows me at the the text "script (1)", like in the video.
But no cwm after reboot. And now the stock recovery seems to be broken. Before installing this apk, i coult boot into stock recovery with rom toolbox for example. Stock recovery with volume plus and power button doesn't work on the Union (on the Iron no problem). But it's the same problem - black screen. So for now recovery seems to be completely broken 🙁
Marcus
What do you mean only apk? Please disable your Windows Anti-virus first or anything that prevents the full download. This "method" is called the manual method (like is normally done by others models/brand) BUT a note here you MUST already be rooted. Without root you are forced to to flash recovery from PC only (but using this CWM/TWRP is this particular one given especially the CWM which is a generic version)You have to rename the files to just "recovery.img"!
This is what it should look inside the zip file , I had attached in my previous message. Please find the attached zip file first. I didnt put in any script file inside there so I dont know what you are referring to. Copy the "Rk3188_CWM.img" into your internal sdcard (You have to rename it to just "recovery.img" ) Run the Recovery flasher get them to recognise the "recovery.img" (It has been 3 years since I last installed CWM/TWRP on RK3188.)
Just make sure you dont mix them up. I hate using button combinations to get into recovery , I recommend you use : https://play.google.com/store/apps/details?id=com.siriusapplications.quickboot . Just press the icon and select reboot /reboot into recovery/ power off/ ect , ect.
NOTE : ALL OF THE ABOVE INSTRUCTIONS ARE TRUE ONLY IF YOU HAVE ROOT WITH BUSYBOX INSTALLED
2016/03/11
I mean the com.arctablet.arctools.apk from the link on page 1.
When i download this, it's only the apk file.
So i save the Rk3188_CWM.img from your attached zip file on the sd card and rename it in recovery.img.
Then i install the Recovery flasher. In the folder recovery flasher in the zip file there are 3 apk file.
Which one should i take? "Recovery Flasher\Recovery Flasher-com.kannan.recovery.flasher-1-v1.0.apk"?
By the way i got my stock recovery function back by installing the original firmware image from axdia again.
Marcus
I told you I forgotten the app that I used to flash this recovery it has been 2 years already,that is why I gave you a few options try them for size. Try Rashr then Kannan. I am currently more into MTK rather than RK SoC
2016/01/24
Hi all,
I want to update my tablet to KK but my Windows 10 doesnt install the drivers like it should. I´m fighting with it for about 2 days.
The only way to check the loader is with rockchip batch tool?
I have Cube v2.06 20131029 Kasty ROM - Darthjabba mod in CWM upgrade format (18 January 2014 - with overclocked kernel "T14" build, based on kernel #12 ). Can I install a KitKat CWM rom? If so could you provide me the best cwm instalable rom?
Thansk
Sorry friend, the best no complication method is to use Win 7 OS. To use Win 10 for RK flashing process is either complicated for novice users or it will not work at all, bcoz the drivers were not meant to be used with Win10 ( the best is only Win8 not even Win8.1)
2014/06/02
cracktech
Sorry, but you are wrong there about Win10. I do use all RK- Win-tools under Win 10, and it works perfect.
The problem for most users is to get the adb (bootloade)drivers installed properly. For this, Win 10 must be "New Started" with the shift-button pressed, then you can choose in the upcoming Win-Problem Screen Advanced Options > Change of startup mode > Restart > select 7 or F7, andWindows reboots with Driver signature check disabled. Only after this you can install the drivers and make them functional.
greetz, daddle
2014/06/02
Hello Oma,
I just put your CWM-recovery sucessfully without any problems on two Medion S7852, rooted with "kkorc"
I did use your generic "(OMA / CrewRKTablets) CWM Recovery 6.0.3.1 for Android 4.4.2 KitKat on RK tablets (loader Gen2)".
Thank you very much, daddle
Thank you daddle for feedback!
daddle said
cracktechSorry, but you are wrong there about Win10. I do use all RK- Win-tools under Win 10, and it works perfect.
greetz, daddle
Thanks for the input but I already know this but see my above reply to "To use Win 10 for RK flashing process is either complicated for novice users or...............". That is the point.
2014/06/02
Yes I did understand this. But all new PC nowadays come with Win 10, and so we shouldn't disencourage those Users with a Win 10-PC. The statement "or don't work at all" is not correct.
Installing drivers on a booted Win10-PC with driver-signature verification switched off works fine, even with the Drivers for Win 8. At least for me on 2 machines with installed Win 10.
daddle
149 Guest(s)
3 Guest(s)
Devices in use: Desktop (138), Phone (11)
spiik
nikitamaan
VMILCINOV
