ClockworkMod (CWM) Recovery easy install on RK3066 and RK3188 devices
leslie_md
196
2015/06/03 - 23:58
@ Oma
Danke für deine Aufklärung. Du hast schon recht, man nutzt die Recovery ja nicht 10 mal am Tag. Ist ja auch nur ein kleiner Schönheitsfehler, wobei ja viel wichtiger ist, dass die Recovery auf dem Medion s10334 super funktioniert.
Vielen Dank nochmal dafür.Smile
By the way: Ich dachte hier wäre alles auf Englisch. Geht zwar noch so gerade bei mir, aber so ist es doch etwas einfacher für mich.
Gruß Michael
Madboy1
197
2015/06/14 - 16:15
I have a tablet mls iqtab1010. with processor mtk8389 .... Do you Know what program I make flash ROM? I have a Roma but do not know if gets flash, sending you a link with the Roma to tell me if is because the tablets became brick
http://www.mls.gr/?pid=165&la=1&itmID=302
Warimation
198
2015/06/18 - 01:06
Hey guys im new here. After some months trying to root my tablet (qilive 10.1) finally nailed it. Now im trying to get a custom recovery but cant find any..  So I was wondering if this cwm will work in rk3188T. Thanks in advance
199
2015/06/18 - 09:45
Yes.
Warimation
Warimation
200
2015/06/18 - 14:48
well its working but gives me some errors..
E:Can´t find  misc
E:Can´t mount /cache/recovery/command
E:Can´t find misc
E:Can´t mount /cache/recovery/log
E:Can´t open /cache/recovery/log
E:Can´t mount /cache/recovery/last_log
E:Can´t open /cache/recovery/last_log
E:Can´t find misc
201
2015/06/18 - 16:10
Is this from the first boot? Try to do a backup.
Warimation
Warimation
202
2015/06/18 - 16:45
ty for your worries but already solved the problem.. human error :p
I´ve flashed the wrong CWM (first one) instead the latest one..
Now all working and no issues.. 😀
My device is Qilive 10.1 q.3778 with rk3188T
203
2015/06/18 - 16:48
Fine.
djchester22
204
2015/07/31 - 18:49
Hello .
I'm new on this forum. I would like to know that this arctools will work on me Tolino tablet 8.9, with 4.2.2 . I want to install CWM to backup my official software. If yes I must put "ROCKCHIP generic (RK3066, RK3188) ......
Thank for your reply
U3CWM
205
2015/10/04 - 10:51
hi All,
Just want to drop in and say thank you for the person who made this apps. I have a Pipo U3 with 4.4.1 firmware and there is no official or non official CWM exit for it. I stalled this apps and installed the package which works smoothly on the first try, much easier to access the backups or restore firmware.
You really did an excellent work.
Keep up the good work.Cool
206
2015/10/04 - 10:55
Thank you for feedback!
dededede
207
2015/10/18 - 10:25
Run on :
Tablet TAKARA mid99b (RK3026)
208
2015/10/18 - 10:48
533online
209
2015/11/24 - 09:09
Pardon my density, can someone tell me how to upgrade a Pipo Max M9 running Jelly Bean 4.2.2 to Lollipop? Is the OMA Lollipop firmware I dled from CrewRktablets stable, and complete? I have not been able to upgrade from 4.2.2 with Rocktools,  any method with a usb cable, long connector or otherwise. Will the ARCtool shown above work on the OMA firmware? How and where, in what folder do I upload the firmware to the M9, on  internal flash or external tf card, for the Arctool to recognize it on the M9? Do I have to rename the firmware to something like update.zip? Do I unzip it or leave it zipped?
Can we get more specific instructions  on the Arctool? What format/naming convention the firmware has to be in for the tool to see it and use it? Where on the tablet does the firmware have to be loaded?
penkal
210
2016/01/07 - 09:51
Good job. It's very nice. ilove it
79 Guest(s)
Devices in use: Desktop (70), Phone (9)
cutierogue
hans41
rickybk
