ClockworkMod (CWM) Recovery easy install on RK3066 and RK3188 devices
181
2015/01/09 - 21:58
Owners of devices based on Rockchip RK3288 processor may be interested in TWRP/CWM Flash-Tool and root by Oma7144 & Crew RKTablets, check this topic.
We'll eventually make ArcTools packages for these recoveries if there is interest for that, please let us know.
maikal
costaqui
182
2015/01/14 - 10:09
I have the same problem on a Qilive 97R-V2. Does it have a solution?
Thank you.
lPersona said
Doesn't work for me..i've successfully install CWM, but i get these errors in cwm:
E:Can't found misc
E:Can't mount cache/recovery/log
E:Can't open cache/recovery/log
E:Can't found misc
E:Can't mount cache/recovery/last_log
E:Can't open cache/recovery/last_log
E:Can't found misc
.I can't do anything except for reboot system and reboot recovery..i have a rk3066 device..i'll really appreciate your help..thanks
Didju
183
2015/01/24 - 15:54
Hi Guys,
- MEDION LIFETAB MD10334 (Lenovo RK3188 Based + stock 4.4.2 rooted)
Working like a charm using (OMA / CrewRKTablets) CWM Recovery 6.0.3.1 for Android 4.4.2 KitKat on RK tablets (loader Gen2)
Can backup rom on external SDcard.
The only issue is upside down screen in CMW.
Thx for great job ;)
peet87
184
2015/01/27 - 16:37
Hello Guys, i can't get a working cwm on my odys gate (10" - 1280x800) with rk3188 (4.4.2 rooted) I've tried many things like arctools; flash via stock rec.; adb; etc. i also found a twrp-recovery for 3188, the same...
Hope you can help me out or point in the right direction.
regards
desmog21
185
2015/01/29 - 12:11
Does this work on Ifive mini 3gs?
186
2015/01/29 - 12:23
These CWM packages are for Rockchip based devices, the iFive Mini 3GS is Mediatek based so it won't work.
desmog21
187
2015/01/29 - 12:31
Thanks for your prompt reply...do you have the CWM package for iFive Mini 3GS?
188
2015/01/29 - 14:56
Sorry, I have no particular CWM to recommend for that platform.
LuckyMe
Forum Posts: 29
189
2015/02/02 - 22:50
It doesn't work on the RCA 10 PRO -
3188 with a 400 mali
4.2.2
1024 X 600
I rooted the tablet with Root Genius, that installed KingUser. I installed the arcTools app.  I can download the CWM package, install it after kingUser grants permission, the image flashes, script running... But a reboot bricks the tablet, Until the battery is drained and the tablet is put on the charger.  Then the tablet will boot back up without CWM flashed.  I tried 3 times, lol.  Same response each time...
But thanks for your work.
marcooleo
190
2015/02/12 - 22:17
Hello!
I have a rooted Cube U25GT-W4 and want a custom recovery like CWM or TWRP, but have not yet find any. So i wonder if anyone know where to find a suitable recovery, or if it even exist one? Here are some info about my tablet:
Model (from the backside of the tablet): U25GTW48GB150049880570
Info from the buildprop (rooted):
ro.build.description=rk3k312x-eng 4.4.4 KTU84Q eng.huangcd.20150118.061017 test-keys
ro.build.incremental=eng.huangcd.20150118.061017
ro.product.device=RK312X_KK
ro.product.board=rk30sdk
ro.fota.oem=skyth-tek312X_KK
ro.productcpu.abi=armeabi-v7a
ro.fota.platform=RK312X_KK
ro.rksdk.verson=U25GT-W4_V1.0_2014.12.28
Would be very grateful for any help! Thanks in advance.
CUBE U25GT-W4-8GB
RK 312x
PLEASE NOTIFY ME IF CUSTOM RECOVERY IS AVAILABLE FOR THIS MODEL. HIGLY APPRECIATED!
sherrif68
191
2015/02/20 - 01:52
Just wanted to confirm I have been brave enough to try this on an Amicroe AMI-TT4 (TouchTab 4) 9.7" tablet. Installed without issue. Any suggestion on custom ROMs to try would be helpful?
versus101
192
2015/03/30 - 12:29
Good Morning People
Before downloading this please read
After using this I bricked my tablet luckily after a lot of trying I managed to get the green flash light and flash my Versus to Cnm stock file ( Jellybean 4.1)
I think this version is a deliberate bricker that the up loader is trying to make money off it may well work for some but for most it WILL BRICK !!! I have both the flashing tool and the Cnm stocker firmware that will work on versus 10.1 tablets should you need it as long as u get the green light on the flashing tool when you plug in your bricked tabl;et you will be able to flash it back to stock firmware and recover your bricked tablet I will not charged for this software like this person is doing just send me a note on where to send the software I will upload the package to a torrent or file sharing ste at a later date
DO NOT TRUST THIS DOWNLOAD YOU WILL BRICK YOUR 10.1 VERSUS/CNM TABLETS !!!! YOU HAVE BEEN WARNED ITS AT YOUR OWN PERAL
glaporta
193
2015/04/10 - 22:45
Hello People,
I m using CWM for Android 4.4.2 recovery based v6.0.3.1 by OMA RK3188 installed from ArcTools. It is working perfectly for restoring and backup via external sdcard. I would like to know if it is possible to get a version of it with restore from USB either, since I have a board-device locked into a box. Is it possível someone to suply a version of it and the price for a special donate in cause of someone wants to develop it to me.
Thanks,
giovanni
leslie_md
194
2015/06/03 - 13:25
Hi Guys,
I'm a new member since today and my English is not so well, but I will try my very best.
I got the same problem as Didju.
I also own a Medion Lifetab s10334 (Lenovo RK3188 based + stock 4.4.2 rooted) and installed (OMA / CrewRKTablets) CWM Recovery 6.0.3.1 for Android 4.4.2 KitKat on RK tablets (loader Gen2).
So everything works fine except the screen in CWM is turned upside down.Frown
Are there any solutions to fix this problem?
Thank you for your help and Thanks for the good work.Smile
195
2015/06/03 - 17:22
Die CWM dreht die Screen so, wie es der Kernel vorgibt. Somit gibt es dafür keine Lösung.
Ich denke aber, so oft wirst du nicht in der CWM unterwegs sein, dass ein simples Drehen des Tabs lästig wird 😉
139 Guest(s)
3 Guest(s)
Devices in use: Desktop (128), Phone (11)
spiik
nikitamaan
VMILCINOV
