2013/05/18
Until now, the package "iFive X2 Android 4.4.2 CWM Recovery by ManuPC" to enable CWM Recovery on KitKat tablets was enabled only on models that were reported to be compatible. There are many requests to enable it for other models, so we did. It should now be visible to any tablet.You can try on your Rockchip based KitKat tablet, please report how it goes to help the community.
The usual disclaimer applies:Â our application and CWM package come with no warranty for any use; you use it at your own risk. Make sure you first have a backup of your data before testing firmwares or recovery procedures.
hy maybe you can help me, I dont no what tablet is  this  ,  I'm not see nothing on tablet, but work with rok tools RKBatchTool1.5en
2014/08/29
I had to use hand gesters to operate though. Use gestures on the touchscreen: touch and move up to select up, touch and move down to select down, swipe left to accept or swipe right to go back.
2014/10/28
Doesn't work for me..i've successfully install CWM, but i get these errors in cwm:
E:Can't found misc
E:Can't mount cache/recovery/log
E:Can't open cache/recovery/log
E:Can't found misc
E:Can't mount cache/recovery/last_log
E:Can't open cache/recovery/last_log
E:Can't found misc
.I can't do anything except for reboot system and reboot recovery..i have a rk3066 device..i'll really appreciate your help..thanks
2014/12/18
I am a new member and have read this Forum with interest and hope someone can advice me. I have a Samsung Quad Core 2.0GHz Tablet Model P9700 9.7 inch Screen Android 4.4.2 DDR4GB HD 64GB, Processor Model:Cortex-A9 and RK3188, Kernel Ver. 3.0.36+ dont@dont #319. I have already rooted this tablet.
My question is would your ClockworkMod work for this Tablet?
Thanks for your feedback, I was about to post that you can have a try, there is no much risk if your tablet is rooted, if you have a backup of your data and a copy of the original manufacturer's firmware.
2014/12/29
working great on cdr-king FP-020-VE not only backup recovery but a whole entire apps+password its so great.thank you for this...
first i install this arctools then i backup after whole process of backup i factory reset my tab then restore my backup then viola all my apps,settings,etc are back so great...again thank you for thisÂ
2014/12/31
Just purchased CHUWI V17HD , trying to connect to Google thru add Account  results in an error , "Servers were not connected .... "
1. Does the V17HD 3rd gen by Oma KitKat build v1.0  solve this problem ??
2. How do I install V17HD 3rd gen by Oma KitKat build v1.0 on the tabletÂ
I guess How do i download it from the PC to the tablet?
Currently Online: VMILCINOV
138 Guest(s)
3 Guest(s)
Devices in use: Desktop (130), Phone (9)
spiik
nikitamaan
VMILCINOV
