ClockworkMod (CWM) Recovery easy install on RK3066 and RK3188 devices
Thanks Received: 3177
2013/10/26 - 20:21
Here is our new ArcTools package designed to facilitate ClockworkMod (CWM) Recovery system installation on your device. This should work on most Rockchip devices running RK3066 or RK3188 processors.
Requirements and compatibility:
A rooted firmware is required, if you are not running one of our Kasty firmwares, you should be able to find one for your device in our forum.
If you are using a different firmware and ArcTools is not pre-installed, you can download it here:
Arctools apk
Following a few days testing period, we have gathered enough positive feedback from the testers and this package is confirmed to work on the following tablets:
Cube U30GT (RK3066) tested by admin
Cube U23GTC4-W (RK3188) tested by admin
Cube U30GT2 (RK3188) tested by Sethi, thantos and DaezD, saciorlux and robiom
Cube U39GT tested by manu_katz
PiPO M9 pro (RK3188) tested by cracktech and yabalis
Pipo M9 pro (Android KitKat firmware) tested by admin, using ManuPC recovery package
Pipo M6 max tested by Balrog
ifive mini2 tested by juliusdapat
Using ArcTools to install CWM Recovery
We haven't yet written documentation for this CWM installation process but the video below shows the main steps. If anyone wants to help the community with the documentation, feel free to post here.
(edit 2014/01/14) ManuPC CWM Recovery for Android 4.4.2 KitKat firmware
If you are running an Android 4.4.2 (KitKat) firmware on your Rockchip device, we recommend using this package:  "iFive X2 Android 4.4.2 CWM Recovery by ManuPC". Thanks ManuPC for providing this recovery image.
iFive_X2_Android_442_CWM_ArcTools_package_b.pngImage Enlarger
(edit 2014/04/16) OMA CWM Recovery for Android 4.4.2 KitKat firmware
The "iFive X2 Android 4.4.2 CWM Recovery by ManuPC" that is listed above is a good option for anyone looking for a ClockworkMod (CWM) Recovery on a RK tablet running KitKat. Still it has limitations such as not being able to support sdcard for storage.
It's been a while that Oma, the great developer from Crew RKTablets has made a custom CWM that fixes the problem. With Oma's permission, we have made an ArcTools package with this recovery image, it should appear in your ArcTools package list under the name:
"(OMA / CrewRKTablets) CWM Recovery 6.0.3.1 for Android 4.4.2 KitKat on RK tablets (loader Gen2)".
OMA_CWM_6_0_3_1_b.pngImage Enlarger
Please note that both ManuPC and OMA packages should be used only an Rockchip based tablets running Android 4.4.x (KitKat) with a Gen2 Rockchip loader ( RK3188Loader(L)_V2.xx.bin )
To check your Rockchip loader version, after you load a firmware in Rockchip Batch Tool, the version appears as you can see in the picture below (illustration shows a Rockchip loader 2.10 on a PiPO M9 KitKat firmware)
Normally all Android 4.4 KitKat firmwares from the manufacturer are using a Rockchip loader version 2
(the number shown in Rockchip Batch Tool should be 2.something). To our knowledge, no manufacturer have provided KitKat firmwares based on a Rockchip loader, there are only a few custom firmwares from independent developers such as Crew RKTablets.
Controls in CWM Recovery
Controls are done thru hardware buttons on your tablet : Vol-/Vol+ to go up and down, power button to validate choices. For tablets without these hardware buttons, you can either use a keyboard/mouse connected to your tablet using an USB OTG (Other the Go) cable, or use gestures on the touchscreen: touch and move up to select up, touch and move down to select down, swipe left to accept or swipe right to go back.
(NEW!) 2015/01/09: TWRP/CWM Flash-Tool and root for RK3288 devices by Oma7144 & Crew RKTablets, check this topic.
The usual disclaimer applies: our application and CWM package come with no warranty for any use; you use it at your own risk. Make sure you first have a backup of your data before testing firmwares or recovery procedures.
Thanks to fun_ from androtab.info, ManuPC and OMA (Crew RKTablets) for their CWM Recovery build.
cracktech, griff2, hardi435, validatus, TabUser99, DominiqueL, junke17, Ohamn, globula_neagra, hasanpb, Wintermute, maikal, Charly26, zhoreb, Balrog, csjanne, Reini, mitsu_58, jrgalang, mirabox, xxmichibxx, fratello, francsal, TecKnight, ldml, G B, rodeomb, Gravi, leechmilk, Amboss, shen129, BigMihca, the tester, rockabilly, Uznamer, pipotablet, wuith, chiaraGI, ecki2k, freeman1778, solaaren, GuidoD, f0o, mrigank, barakafrite, 2ndwing, bikervn, gmax_jp, Hitm@n, marek.w, j.kowalski83, waschbaer77, Buha, ri9000, Celtic67, olowokandi, cloneme, honaga, AllmightyThor, XXX-Man, zakaeda, U3CWM
tullm
Thanks Received: 7
2013/10/26 - 21:50
Thanks a lot!
worked great on my PiPo M9 pro WiFi with Riley Rom 1.7b.
regards
tullm
The following users say thank you to tullm for this useful post:
interesting.items, gogojoe, houwang, polturgiest, j.kowalski83, Buha, DECEBAL
griff2
Sarlat
Forum Posts: 11
Thanks Received: 4
2013/10/26 - 22:49
Yes, many thanks. (The penny finally dropped!)
jesmail
usa
Forum Posts: 26
Thanks Received: 5
2013/10/27 - 01:22
Eyes must be getting bad, can not see the link to download the app. Where is it?
Thanks...
larry345
2013/10/27 - 04:20
Thanks...
I think  you just open this page in the browser: http://www.arctablet.com/blog/downloads/tools/arctools/com.arctablet.arctools.apk/, then click on link and install.
jesmail
usa
Forum Posts: 26
Thanks Received: 5
2013/10/27 - 04:57
That seems to get me version 0.80, where is the new one?
The following users say thank you to jesmail for this useful post:
stepole
jesmail
usa
Forum Posts: 26
Thanks Received: 5
2013/10/27 - 05:01
Never mind, found it....
jschneider3486
marcobus2005
Forum Posts: 18
2013/10/27 - 06:16
perfect on my u30gt2.
Thanks!
2013/10/27 - 11:20
For those who don't have it pre-installed in their firmware, I've added ArcTools download link in post #1, latest version is currently 0.80.
maldan12
2013/10/27 - 13:05
Thank you so much !
DominiqueL
Forum Posts: 12
Thanks Received: 5
2013/10/27 - 14:49
Works like a charm.  Install is a piece of cake  (installed on M9 pro wifi with lastest kasty rom 21031023)
Tks for the good work.
Cube U30GT2    4.2.2 rooted SDK2.0
Pipo max M9 pro wifi  4.2.2 rooted
Zopo zp 980 Turbo rooted
Asus Zenfone 2
kruegger
2013/10/27 - 18:29
Very nice, Thank you! Works fine on Cube U35GT2 with Kasty 4.1.1.
lsdove
portugal
2013/10/27 - 23:20
Works great, Tks so much.
The following users say thank you to lsdove for this useful post:
Dungleanh83
toom11
2013/10/28 - 06:16
Works very feine on my U30GT2  with 2.06 and Kernel 38 1.8GHz Mod.
Thank you
voynix
Forum Posts: 17
2013/10/28 - 22:23
Thank you. Worked fine for me on U30GT2 with 2.04 kasty.
74 Guest(s)
Devices in use: Desktop (69), Phone (5)
WhiteD2125
Bokser
hamishduke
squal
squalangel
anqilan456
