Arnova 7b g2 dt(resistive) - manage applications is not working after flashing it with archtools (1.12 EZ firmware)
cmvrgr
2012/06/27 - 12:31
Arnova 7b g2 dt (resistive) after flashing it with archtools (1.12 EZ firmware) manage applications is not working so i can not install or uninstall any other application.
Also in my sk17i (SE XPERIA PRO) I can install my applications directly from my sd (apk files) in arnova 7b g2 DT I can't it gives "Parse error"
I would like to thank in advance for your time
Thanks Received: 3169
2012/06/27 - 12:35
cmvrgr said
 arnova 7b g2 dt (resistive) after flashing it with archtools (1.12 EZ firmware) manage applications is not working so i can not install or uninstall any other application.
Also in my sk17i (SE XPERIA PRO) I can install my applications dicectly from my sd in arnova 7b g2 DT I can't it gives "Parse error"
I would like to thank in advance foir your time
Which error are you getting in Settings / Manage applications ?
The Parse error usually come from APK files that are made for a different Android version or require specific libraries...
cmvrgr
2012/06/27 - 12:48
I am uploading screen shots of the erroe mesages if that helps...
I have installed my apps to various Android phone / tablets.
This screenshot when I select manage applications
shot_000002.pngImage Enlarger
This when I trying to run any apk app....
shot_000003-1.pngImage Enlarger
sp_PlupAttachments Attachments
86 Guest(s)
Devices in use: Desktop (80), Phone (6)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
