Arnova 7 G2I Arctools dont work
morph
2012/09/17 - 16:24
hi, i have the  arnova 7 G2i ics ,but archtools wont instal google play,are there any planned updates to fix this?
Thanks Received: 3169
2012/09/17 - 16:39
I'll add Arnova 7 G2I support later in ArcTools.
In the meantime, you can flash our custom firmware using Rockchip tool:
http://www.arctablet.com/blog/featured/arnova-7-g2-firmware-upgrade-android-4-ics-google-play-root/
morph
2012/09/17 - 16:48
brilliant that was my next question.
thx for the quick answer :)
morph
2012/09/17 - 17:31
ok ive a problem,when trying to run the rockchip flasher tool all i get is loading config file failed(even if i run as admin)it opens up but in chinese,any idea why?
im running win 7 ultimate 64 bit.
EDIT problem solved,i was using power archiver to open the zip. doh
morph
2012/09/17 - 17:52
stupid questions,but should the usb be plugged in while im entering recovery/flashing mode? and where it says to turn off the tablet in step 1,shouldnt it be on to enter recovery/flash? as mine does nothing even after holding the paperclip for around a minute.
confussed
74 Guest(s)
Devices in use: Desktop (69), Phone (5)
atgyuric
BBonch
crispyduck00
asgard2701
Rob_nl
shadowlabs
Topics: 6028
Members: 261274
