ArcTools package "disable/move Phone.apk"
2013/06/04 - 11:24
This ArcTools package helps to disable the phone/cell radio functions on any Android device.
What it does is just move /system/app/Phone.apk file to a backup directory /system/appbackup/ (in case it needs to be re-installed)
This simple modification is supposed to help improving the battery life on some devices and was reported to work successfully on the Cube U3GT2 tablet. Initially based on jellybellys mod, the package has actually being simplified, thanks to DarthJabba's feedback.
The package install will require a stock tablet (preferably running our kasty firmware) obviously with Phone.apk still installed.
Quick usage instructions:
1. Start Arctools application, it should be installed if you are running our kasty custom firmware, else you can download latest update here: com.arctablet.arctools.apk
2. Select "Disable/move Phone.apk"  in the packages list.
3. Press Download button, wait for the quick download to complete
4. Press Install apps button
You'll have to Grant access to Arctools when you get a SuperUser request, this is required to allow copying system files.
After the script has run, wait a few seconds and restart your tablet.
5. please verify that the script worked and the Phone functions are gone and let us know Wink
One caveat of this script, as DarthJabba pointed out is that the About tablet / Status menu will make the Settings Force Close.
Thank for your feedback.
szmeron
Poland
2013/06/04 - 12:41
Hello
I have two errors: 20 and 28 when I'm trying to install disable/move phone.apk
How can I fix it?
Regards
2013/06/04 - 12:44
You need a rooted system, such our kasty firmware, is that the case ?
BapeBape
szmeron
Poland
2013/06/04 - 12:59
Today I installed the latest kasty firmware. I have superuser pro too
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/04 - 13:04
Im with the same error (28 and 20). Using last (06.01) kasty ROM and with superuser...
kykif
Forum Posts: 15
2013/06/04 - 13:35
I have the same problem. I use the last kasty firmware.
Somebody have an idea ?
DarthJabba
Forum Posts: 551
Thanks Received: 396
2013/06/04 - 13:52
Works here. I also got those two errors again first time I ran it - then I remembered I had already renamed Phone.apk. So I put it back, and ran again, and got no errors this time.
DarthJabba
Forum Posts: 551
2013/06/04 - 13:56
kykif said
Run it again. Then reboot and see whether the "phone radio" is eating battery life. A good tool to use for this is "GSam Battery Monitor" (available free on Google Play). If the mod worked, then "phone radio" will show 0% power use.
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/04 - 14:04
i already rebooted.. installed fresh ROM.. gave SU permission and still get the same error codes 20 and 28..
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/04 - 14:07
My Solution:
Tried first time: no goo.
Rebooted: tried second time, SU lunched and asked for permission. i Granted permission tried to install: no go.
Rebooted again, after gave SU permission, and tried to install again: now it did work!!
Check if it works this way for you too kykif.
kykif
Forum Posts: 15
2013/06/04 - 14:31
It's OK ! Thank you from Paris Sethi ! ;)
szmeron
Poland
2013/06/04 - 14:34
After reboot I see arclogo only and few seconds later the tablet hangs:).
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/04 - 14:35
Thats a known issue. when that happens you need to push power button till it forces turn off than reboot again.
Sethi
Brazil
Forum Posts: 93
Thanks Received: 10
2013/06/04 - 14:36
Glad it did work for you too!
szmeron
Poland
2013/06/04 - 14:51
I know but it's really frustrating:)
59 Guest(s)
Devices in use: Desktop (57), Phone (2)
