Arctools 0.57 stops at error 20 and 28
Related Tags
Bert Lubbers
Exloo, NL
2011/11/07 - 20:33
I installed arctools 0.57 on my brand new Arnova 10. Downloading the market app went well, but installing failed. Error code 20 and28 appear. Does anyone have any clues on solving this issue? Should I have access as a superuser? How can I become a superuser?
2011/11/07 - 20:46
Hello Bert,
Arctools was designed initially for Archos Gen8 devices.
It expands over time to other tablets, but requires root access or a modified firmware to work on non Gen8 models.
For your Arnova 10, you should look for custom firmwares such as:
/blog/archos-tablet/arnova-10-custom-firmware-android-market-root/
Our latest custom firmware (kasty-arn10-22-05) has currently been removed, due to too many problems reported.
We'll try to make an update soon.
http://www.arctablet.com/blog/featured/arnova-10-custom-android-2-2-froyo-firmware-android-market-root-kasty/
daveedrosenberg
2011/11/25 - 20:47
updated my archos7 htv2  model a70bht to froyo 1.0 with android 2.21; when i open the arctools .56 app and try to download the associated apps i get "error code  28 can't create temporary directory. Is there a way to fix this problem.  Thanks in advance
daveed
2011/11/25 - 21:21
Thanks Dave for posting here rather than expecting an answer thru private email [Image Can Not Be Found]
Arctools is actually compatible with all Archos Gen8 devices and some Archos and Arnova models.
Regarding your Archos 7 HTv2, Arctools is compatible with specific older firmwares that are not up to date anymore.
If you are using this firmware (which seems to be the case in your message), Android Market is included and Arctools is not required.
Shane-m
2011/12/28 - 00:37
which version of arctools should you have for arnova 10 g2
drchips42
Forum Posts: 38
2011/12/28 - 15:40
arnova 10 g2 2.3.1 arc tools .. error 28 etc.. etc..
if the only answer is to re image , why put the app on the rubbish applib in the first place ?Yell
HTC Desire CM7.1, Arnova 10G2 ( stock rom ) All Google products fully working!!
col2802
Forum Posts: 26
2012/04/19 - 22:28
I'm having the same issue, I've just bought an arnova 9g3 and am worried about installing a custom firmware as I have the feeling it was the reason why my old 10g2 bricked on me, not found any info for g3 yet and the arnova website can't help as it only allows you to register and query upto 2gen
uniuk2001
2012/04/23 - 17:20
I've also got a 9 G3. They are only just trickling out onto the high street. Best be patient and wait for 3rd party roms to be developed.
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/04/24 - 00:47
We will add arctools support for the Arnova g3 line-up once we will get our hands on one. So far, we don't have any, so we can't do anything. 🙂
Thanks Received: 268
2012/04/24 - 00:56
Mate, do you still have the tablet ?
col2802
Forum Posts: 26
2012/04/24 - 07:46
Hi globula, I still have the g3, the g2 went back to the store, I had it for 3 days and it crashed at least twice a day, didn't want to risk it happening again with the same model so I went for the g3
2012/04/24 - 09:12
thx for the info, i thought that you still have it, i want a bricked 10g2 😀
52 Guest(s)
Devices in use: Desktop (44), Phone (8)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
