Arctools 0.56 won't start
Mel
2011/11/05 - 14:53
Hi, I've just purchased an Archos 101 as a Christmas present. I'm try to load arctools which seems to install, but won't start. Error message... application arctools 0.56 (process com.arctablet.arctools) has stopped unexpectedly, please try again.I updated to the latest firmware and I've tried resetting the tablet and re installing but same error. Any ideas ?. Many Thanks
Thanks Received: 3169
2011/11/05 - 15:50
I just tried latest version (0.56) on an Archos 101 IT 8 GB, I had no problem on both firmwares 2.4.19 and 2.4.65.
Can you try again to run the application, and let us know if it still force closes.
Thank you.
Mel
2011/11/05 - 16:03
Hi, thanks for the quick reply, I've just uninstalled, rebooted and re installed but same error. Thanks
2011/11/05 - 16:20
Is your device connected to Internet when ArcTools is started ?
Can you try this older version, as a test ?
/blog/wp-content/uploads/2010/12/com.arctablet.arctools.apk.050
Download the file, rename it to com.arctablet.arctools.apk and install it on the device.
Thank you.
Mel
2011/11/05 - 16:54
Thats worked, now have arctools installed thanks, excellent service!
daknin
2011/11/05 - 17:09
Hi, I am also seeing the same problem using ArcTools 0.56 on my new Archos 70. I've unsuccessfully tried installing on firmwares 2.4.19 and 2.4.65. I managed to install Android Market using ArcTools 0.50 from above with firmware 2.4.65. Upgrading to ArcTool 0.56
sfrailroader
2011/11/05 - 19:16
Maybe I am missing something... I am not able to get ArcTools 0.50...
2011/11/06 - 10:17
ArcTools 0.57 should definitely fix those issues.
The application is available on Appslib and for download on Arctablet Blog, see essential tools on the right column on the Blog: http://www.arctablet.com/blog/
daveedrosenberg
2011/11/25 - 20:51
updated my archos7 htv2  model a70bht to froyo 1.0 with android 2.21; when i open the arctools .56 app and try to download the associated apps i get "error code  28 can't create temporary directory. Is there a way to fix this problem.  Thanks in advance
daveed
Currently Online: budmo
94 Guest(s)
Devices in use: Desktop (80), Phone (14), Tablet (1)
emiliusnotes
abdelouahabido
ble1x
darlaive
bogdushok
Torn
Topics: 6011
Members: 260682
