2017/03/05
hello all,
i'm new here and also in software debuging/repair android tablet/phone,
ok,
i have an alcatel one touch evo7 brick , when is boot up apaire operator logo and in freezing there
i try many methode but nothing, i can't not install driver, or i not able to do, i dont know, this is not a first meeting
when i reflah a phone
i will tanks ho anybody ho give me a link or sugestion how can i resolv a tablet
i try whit RKAndoid tools , in message box apaire "Found RKAndoid Mass Storage device" and i can't flash it
what is the problem?
what can i do?
any suggestion are will be recevied whit goodness,
thank all in advance
The tab is not in flash mode. Which Windows?
Here is a driver assistant: http://crewrktablets.arctablet.com/?wpfb_dl=2766
2017/03/05
thank you ,
now it's show "Found RKAndroid Loader"
i make :EraseIDB Â and now it;s not boot up , and do nothing , i belive i erase all from memory,
i don;t know what i need to write in flash side , nfs and ram
i know what means each one but i don;t know what i need to flash firstly...
Yes, eraseIDB will wipe the partition layout on the NAND. Do you have the stock firmware available?
2017/03/05
yes, i have something... i found on web .... , but i give "error flash" in right side cmd when i want to flash it
it is possible to have some hardware problem?Â
but firstly after i erase everything what i need to flash? can you tell me in order pls , like : kernel , recovery , rom
or is not important the order?
i try many way, but unsuccessfully ...
thx again for all
When we are talking about the RK2918 tab, here is the firmware: http://crewrktablets.arctablet.com/?wpfb_dl=1515.
Attached the FlashTool. Just paste the Evo 7 firmware into the right folders.
68 Guest(s)
Devices in use: Desktop (58), Phone (9), Tablet (1)
hakhiem
jenom
kfwacky
fer30
culo1
dfrt
