Tablet not working on forum
leetudor
Forum Posts: 57
2012/01/31 - 14:02
When on the tablet I cannot reply to any topic.  When you click reply it will open a box but tablet cannot type in the box.  Is that normal?
damo
Kingston upon hull, UK
Forum Posts: 243
2012/01/31 - 14:09
you need to go into settings on the browser you are using and change the USER AGENT, normally it is set to android, try changing it to desktop or vice versa and it will workWink
Thanks Received: 3169
2012/01/31 - 14:10
I just tested on my 10G2, I have the same problem.
The edit box opens but the virtual keyboard does not show up.
I'll have a look with the forum system authors, in the meantime I have no idea to fix the problem.
(topic moved in Arctablet website section, as it seems to be a site specific (not tablet) issue)
Edit: Damo thanks for your reply, but changing Useragent is a good idea, unfortunately, it had no effect on the problem here.
leetudor
Forum Posts: 57
2012/01/31 - 17:04
I did not know what type of problem it was just knew at times it was a problem.Laugh
leetudor
Forum Posts: 57
2012/02/03 - 13:34
Any update?
damo
Forum Posts: 243
2012/02/03 - 14:12
What browser are you using with the problem
damo
Forum Posts: 243
2012/02/03 - 14:30
I have Boat browser installed and it does work!
install it from the Android market, in the settings make sure the user agent is set to Android.
Please try and report back, I have sent this post on the mentioned browser on my 10G2 tablet Wink
leetudor
Forum Posts: 57
2012/02/03 - 14:53
I just use the brower that comes with the finless Ron.
leetudor
Forum Posts: 57
2012/02/03 - 14:55
It will work on my android phone.
leetudor
Forum Posts: 57
2012/02/03 - 22:58
Works with Dolphin browser.
damo
Forum Posts: 243
2012/02/04 - 00:00
Cool glad you got it workingSmile
HaroldG
Greater Philadelphia, PA, USA
Forum Posts: 115
2012/02/10 - 06:25
Just tried this myself, first with stock browser, then Dolphin HD.
Stock fails; writing this on my AN10G2 with Dolphin HD.
124 Guest(s)
Devices in use: Desktop (114), Phone (7), Tablet (3)
maxmintus
cngulhane
cipek123
zerpur
Billibon
Enemy777
Topics: 6010
Members: 260663
