new posts icon/check doesnt work anymore
register
Forum Posts: 84
2012/02/29 - 08:13
the (java?)icon on top of the forum table doesnt work correctly anymore
i just log in in the morning right now and it tells me "0 unread posts"
while at the bottom where the unread posts are listed
there are a number of posts starting from just 3 minutes ago
same behavior on two different browsers of two different computers
this started yesterday
Thanks Received: 3169
2012/02/29 - 09:53
Thanks for reporting the problem. I doesn't seem to do it on my account, I'll have a look.
alex
Forum Posts: 252
2012/02/29 - 16:37
i have same problem no icon next to new posts either
2012/03/01 - 11:47
Seems to be a random problem, maybe a server cache issue.
There was a problem for some time here, it worked again then it's bugged now.
I'll keep an eye on that.
register
Forum Posts: 84
2012/03/01 - 21:13
admin - since the java check does not work
and the list below shows just a couple of unread threads
how can i check the new messages on this forum?
2012/03/02 - 09:17
I am still trying to understand the problem, as it seems to happen randomly here. I disabled the server cache and it still happened, so it may not be related to it.
I choosed Simple Press as a forum software because it goes well with Wordpress, it's well supported by its authors, it's very easy to extend and it's free.
While there will always be complaints we should switch to vBulletin, I really want to give this software a chance, the most important glitches have been worked out, so should be this one. I am always listening to remarks regarding bugs and enhancements and I'll make my best to get things running properly.
I'll let you know when the problem is fixed and I am really sorry for the inconvenience Frown
register
Forum Posts: 84
2012/03/02 - 10:30
ok in the morning it was still 0 new posts
now it works - says 8 new posts
hope this helps
2012/03/02 - 10:32
It does help, thank you, but the random nature of the problem makes it a little hard to analyze.
I will update here when progress is made fixing the problem.
2012/03/05 - 11:32
The problem should be fixed now.
Register, can you check and let us know ?
register
Forum Posts: 84
2012/03/05 - 14:34
in chrome clicking on the icon does nothing now
will check later for ie
register
Forum Posts: 84
2012/03/05 - 20:53
same with ie
register
Forum Posts: 84
2012/03/10 - 13:18
any update?
so far the "unread" icon does not work but thankfully the "unread" list at the bottom was showing in a button the unread posts
now even that doesnt work
is there another way to be able to check the new posts?
edit
strange - now suddenly the list works again and shows buttons
the icon still doesnt work
2012/03/10 - 15:19
I am sorry about those problems, it's in the priority list for the things to fix here, but there are quite few other items in the firmware area to finish as well. I'll update here when there are some news.
Thank you.
2012/03/16 - 09:21
It should be fixed, finally.
There were some javascript issues in forum page.
register
Forum Posts: 84
2012/03/16 - 20:26
its working now!Laugh
82 Guest(s)
Devices in use: Desktop (78), Phone (4)
dcatalan
dshepp
kaironit
qweku1
himeji
robotx
Topics: 6028
Members: 261291
