Newbie here but frequent user of other forums - am having trouble posting a reply along with a quote.
If I hit the "quote" button, I get the original msg, in it's own box but I expect to be able to insert my reply, by typing it outside the box containing the original quote - and I cant!
My cursor is sitting at the end of the quote, inside the quote box!!
I don't doubt that the solution is both simple and silly but I just can't see it
quote test
On internet explorer
list=UUnc_A4yn1Amn8wz6q5iXbag&index=1&feature=plcp
Sorry for the shaking hand 🙂
We are using a particular forum system (Simple Press) here that sometimes has a few glitches, could be that you've hit one.When quoting the cursor normally goes after the box around the quote, see attached screenshot.
Which is your OS / browser ?
This seems to be working ok - am using Opera for this.
Previously I was using IE9 and having the problem every time.
What you describe seems to be a bug with IE9 when it comes to quotes display.
I'll see if I can fix this or check with the forum system (Simple Press) team.
Wyeman said
So are we saying that the Forum doesn't support IE9 ???
This post (reply) was achieved correctly using IE9 by doing the following . . .
Clicking the " icon (the double inverted commas) in the menu at the top . . .
this left "Wyeman said" in a box but put the quote text outside of the box . . .
Then I added my text to the end of the quote text - hit c/return to move my text to a new line . . .
then clicked the " icon (double inverted commas) again . . .
that put the quote text back into its' box and left my text outside the box, where it should be.
Does this help "Admin" understand what's happening ???
Currently Online: hoholotus
90 Guest(s)
Devices in use: Desktop (78), Phone (12), Tablet (1)
hoholotus
valentin45200
sacha45200
zeus123
Andrew90
Resident_112
Topics: 6026
Members: 261160
