Archos 80 Titanium WIFI issues
UTO1867
2013/03/02 - 12:37
Although i have seen a similar thread regarding WiFi issues on the 97HD i thought because the 80 is a different device i should start a new thread.
Anyway the 80 Titanium suffers the same WiFi problems. Although i love the tablet the WiFi is flaky and unpredictable even if the tablet is in the same room as the router or access point. I have an 80Mbit VDSL2 connection and i regularly get around 50Mbit on my other wireless devices but with the 80 Titanium i am lucky to get 512kbps at times which results in a lot of buffering (i have tried the access points on g only and it made no difference)
I have raised the issue with Archos but unfortunately they just said try another access point (which i did and it made no difference)
Thanks Received: 264
2013/03/02 - 14:37
Yes, from my experience with the 80 Titanium i have encountered some issues like:
-not being able to connect the WiFi only after i enables also the b standard i had a connection
-on some positions the signal was dropping from 3 lines, to one
-youtube worked fine on me :)
so, some tips, enable all the wifi standards b/g/n
UTO1867
2013/03/02 - 14:46
They are enabled on mine mate, i tried all the wireless standards possible and it made no difference.
Currently Online: VMILCINOV
71 Guest(s)
Devices in use: Desktop (67), Phone (5)
nikitamaan
VMILCINOV
