2013/04/08
Hi guys, i have rooted easily this tablet with one software (Oh yeah, one click root).Â
The proceedings is quick and easy:
1: Download this software: http://products.mgyun.com/api/downjump?id=55
2: Open it (and agree all conditions)
3: Grab your usb cable and connect your tablet at your pc
4: Enable "Debug USB"
5:Now the software will download the info of your device and will recognize the Archos 70 Titanium. At this point will appears a green button, press it and the software will start to install the root. After this process the tablet restarts and after this you  will see a new chinese program in your tablet (obviously it's the root app).
PAY ATTENTION: When you install an app who needs the root, after start it, Â will appear a message for authorize the root; Remember, for authorize always press the right button.
Ps: Do this at your own risk.
For me worked without problems, i wish will be the same for you!
Pps: Sorry for my bad english!Â
The following users say thank you to whirring for this useful post:
flow2013
2013/02/25
Can you make a full dump of your tablet and upload it ? I brick my 70 titanium two week ago.
http://www.arctablet.com/blog/forum/archos-titanium/how-to-root-the-archos-titanium-97-hd/#p20593
he can not use the same way to dump the tablet, since he has root, he should just use adb, and dump the partitions to the sdcard.
2013/06/07
2013/02/25
flow2013 said
hiAdb can not recognize the 70 titanium. how can i fix this?
Have you got a Linux environment ?
EDIT : For adb try this : http://www.archos.com/support/support_tech/updates_adb.html?country=us&lang=us
The following users say thank you to hmsintrepide for this useful post:
flow2013
2013/06/07
Find the solution
http://www.archos.com/support/support_tech/updates_adb.html?lang=en
no, the dump with dd needs to be re-packed in a flashable update.img, if someone can dump, the system/boot/kernel/misc/backup and upload it somewhere, share the link, we will create the update.img
2013/06/07
thanks. it works just fine.
2013/06/07
Pps: Sorry for my bad english!ÂÂ Â
I just try your method and it works. my titanium 70 is now rooted. thanks a lot.
2013/02/25
Can you help me for unbrick my titanium 70 ? can you with terminal emulator apps (on google play) or adb shell type these command (if you have error report it me) It's for dump all system files for create a restore image
$su
#dd if=/dev/block/mtdblock0 of=/sdcard/mtd0.img
#dd if=/dev/block/mtdblock1 of=/sdcard/mtd1.img
#dd if=/dev/block/mtdblock2 of=/sdcard/mtd2.img
#dd if=/dev/block/mtdblock3 of=/sdcard/mtd3.img
#dd if=/dev/block/mtdblock4 of=/sdcard/mtd4.img
#dd if=/dev/block/mtdblock5 of=/sdcard/mtd5.img
#dd if=/dev/block/mtdblock6 of=/sdcard/mtd6.img
#dd if=/dev/block/mtdblock7 of=/sdcard/mtd7.img
#dd if=/dev/block/mtdblock8 of=/sdcard/mtd8.img
#dd if=/dev/block/mtdblock9 of=/sdcard/mtd9.img
#dd if=/dev/block/mtdblock10 of=/sdcard/mtd10.img
Upload it on the web please.
you don`t need all of them, only the system/kernel/misc/boot
66 Guest(s)
Devices in use: Desktop (54), Phone (11), Tablet (1)
culo1
dfrt
PQNY
chema1971
speedyftp
georgicaa97
