[ ROM ] ARCHOS 70 Titanium custom rooted firmware (based on stock firmware 2013/01/29)
whirring
2013/06/19 - 18:36
One thing: For go to the recovery, i press all the button together without connect the usb cable, when compare the green robot i press and hold power button and then i press once the vol + button (like you said). In the recovery i wipe data & cache and reboot. The result? 100% success.
Recapitulating:
-You can install the rom WITHOUT the cable
-If you want go to the recovery there is another way
kroug
2013/06/24 - 12:50
Why can't i dl this file ?
kasty-archos_titanium_70-411-20130129-test1.zip
thx, i need your help
flow2013
Lomé-Togo
Forum Posts: 42
Thanks Received: 12
2013/06/24 - 12:54
Hi. try again. you should be able to download it. i had the same problem but finaly got it downloaded.
kroug
2013/06/24 - 13:05
thx, i refresh 500 times and i have the dl now :)
other questions... i try to connect my tablet to an ad hoc wifi connection, but it is not detected, so i need to modify the wpa_supplicant. Can i do it with super user?
PS: sorry for my english
flow2013
Lomé-Togo
Forum Posts: 42
Thanks Received: 12
2013/06/24 - 13:14
I dont really know as im not having this problem whith my tablet. Maybe somebody else can help you. but if you need root access to modify the wpa_supplicant super user may certainly help you.
hmsintrepide
Forum Posts: 37
2013/07/17 - 13:14
I want to underclock my cpu (and my gpu if I can) for have a better battery life and reduce the heat of the cpu/gpu/battery. I think 1200 mhz is enough for a medium usage. I use some apps (cpu master or cpu tuner) but when my tablet enter in sleep mod the frequency up to 1600 mhz (stock max frequency). How I can permanently set the max freq to 1200 mhz ?
Thanks Received: 264
2013/07/17 - 14:37
use a modified kernel (the source code is available)
hmsintrepide
Forum Posts: 37
2013/07/17 - 16:43
I try it (I quote too high frequency - 1200+ mhz - in cpu freq list), but I have  a trouble when I want to unpack the boot.img image (no header found). I can do it with the recovery.img.
127 Guest(s)
Devices in use: Desktop (108), Phone (19)
Ossir88
DGa
mike666
ielu
IchWillNurEineDateiDownloaden
fafa66
