2015/08/07
Hi guys, i need ur help..
i have rooted my 45c Platinum and delete google crap..but the google store too.. bad idea..i know
After i try some methods to get it back i try to use a costum rom, and its failed.. now my phone has a bootloop and i cant find a solution to bring it back.
I dont have a custom recovery menu or anything only the normal recovery menu (activating with power+ volume up) i try some methos ..like sideload but the installation aborted.
HELP ME PLS!
Hello sempra,
I just checked on archos website and they do not seem to offer any firmware download for the 45c platinum.
Their FAQ mentions the following as a reset procedure:
Turn off the device by using ON/OFF (remove then replace the battery if necessary)
Press simultaneously Volume + and the ON/OFF button until a green robot is displayed
Hold Volume + and press once the Home button
on the font casing
Use the volume buttons to scroll down and up and the Menu button
to validate.
If you failed to access to the recovery menu, please start again from the beginning.
- Select "Wipe data/factory reset" and validate to restore your device to its default settings
- Select "Yes -- delete all user data" and validate to remove all the user data
- Select "Reboot system now" and validate to reboot the device
But it looks like this is the procedure you are following. Depending on what you flashed as a custom firmware, you may not be able to recover your device using that method.
I'd recommend that you contact archos support requesting the stock firmware for the 45c Platinum, it's probably best not to mention how you ended up with a not booting phone
Feel free to share the results, it may be interesting for other users as well.
74 Guest(s)
Devices in use: Desktop (67), Phone (7)
