How to unbrick Archos 50 Platinum sys_boot format
DieterHolvoet
Forum Posts: 11
Thanks Received: 6
2013/08/22 - 14:35
** UPDATE 16/01/2015: sys_boot.img (https://drive.google.com/file/d/0B8L0UK8zvzi2WVdPX2M5NTc4ZWs/view?usp=sharing)
Here's a small tutorial for people who bricked their phone while formatting the sys_boot partition in CWM Recovery. When you format that partition, nothing works except a screen shows up saying "RESET FOR ENTRY QPST DOWNLOAD". This screen is also known as the Qualcomm Diagnostic Mode.
Requirements:
Follow the steps to restore the sys_boot partition:
1. Connect your phone to a pc using the cable
2. Install the drivers if necessary:
https://dl.dropboxusercontent.com/u/17562266/USB%20Modem%20Driver.rar
3. Open your terminal
4. Type "lsblk" (without the quotes).
You should see a list, showing every connected disk and partition. Look for a partition with a size around 50M. This is the partition we need, so remember the corresponding name under the 'NAME' column. It can be "sdc", "sdd" or "sde" followed by a number.
5. Cd to the directory you placed sys_boot.img in
cd [filename]
6. Type "sudo dd if=/dev/NAME of=sys_boot.img bs=512
Replace NAME with the name you got from lsblk, and press enter.
The output should look something like this:
3959420000 bytes (3866621 KB) copied, [ time spent], [KB/s]
7. Remove the cable from your device, do a battery pull and try to boot your device
Normally, it should boot correctly. If you formatted the /system partition too, you have to get into recovery mode by holding the upper volume button while booting, until a red screen appears.
If you have any questions, or if this doesn't work for you - let me know in the comments.
Thanks a lot to Adonis K. and globula_neagra for the sys_boot image and pointing me in the right direction.
The following users say thank you to DieterHolvoet for this useful post:
globula_neagra, Adonis K., Weltonrussell
Device: Archos 50 Platinum, Rooted
If you want to support me, donations are always welcome!
Weltonrussell
2014/07/28 - 16:26
This is really helpful except that the link to the driver [item 2 above] is now dead.  Can anyone help me with a driver link?
DieterHolvoet
Forum Posts: 11
Thanks Received: 6
2014/07/28 - 18:39
Hi Weltonrussell,
I looked around on my hard drive and on old forum posts/websites, and I finally found and re-uploaded the file you're looking for:
Good luck!
Dieter
Weltonrussell
Weltonrussell
2014/07/28 - 19:51
Hi Dieter,
Many thanks.
73 Guest(s)
Devices in use: Desktop (67), Phone (6)
trroll171717
alsoft75
Deaker
Gorael
WhiteD2125
Bokser
