ARCHOS Diamond Plus
This topic will be used as reference for anything that has to do with Archos' new Smartphone
thedean
2016/01/12 - 21:22
The brand new Archos Diamond Plus. A well-deserved sequel to the excellent 50 Diamond. I've bought the phone the day it went out, and here are some flaws it has, as well as a general overview.
Unfortunately when I opened the phone, it lagged very much on locking/unlocking it. I searched the web, Android 5.1 should be free of memory leaks, so I have no clue what's causing it. It takes about 5-8 seconds to light up the screen after clicking the power button to unlock and for another 15-20 seconds after that, anything you press just won't work, or it works after a few seconds. The amount of lag in this phone is irritating and not something that its buyers would want.
On root issues, obviously no on-the-fly rooting methods work, like KingRoot etc. I can only hope that the admins of the site would devote some time on this smartphone and come up with a rooting method that actually works. I can also hope that when this happens, the lagging issues would go away, if they are caused by some app the phone came with.
I'll be waiting to hear opinions from other Diamond Plus owners and admins of the site 😀
thedean
2016/01/28 - 08:31
As it turns out the reason for the lagging was the SD memory card, which, after a couple of restarts was invisible in the phone, its storage space was nowhere to be found (same issue I had with my 50 Diamond, after a couple of restarts the phone would "lose" the memory card, not seeing it anymore).
But this time this brought along this very annoying lag. After removing the SD card, phone got back to normal.
Currently Online: desluk
101 Guest(s)
Devices in use: Desktop (98), Phone (4)
desluk
cimoral
merlin077
nrod
midnight-gr
Pajaro047
