There is a big chance that this phone can be rooted with the fallowing tool
http://download.unlocksamsungonline.nl/SRSRoot-Setup.exe
Of course, the usual stuff, we can not be held responsible for any damage that my appear.
If someone manages to root the phone with this method, please let me know
Unsecure boot.img
ro.secure=0
ro.debuggable=1
Download
http://www.mediafire.com/download/v4o69nfdxllih3h/bootcurrentfirmware.img
Rename the file to boot.img
Flash the boot.img via fastboot.
fastboot flash boot boot.img
fastboot continue
Enable write access on /system partition with
adb remount
Then download supersu and su and do the next things
adb push su /system/xbin/su
adb shell chown 0.0 /system/xbin/su
adb shell chmod 06755 /system/xbin/su
adb push superuser.apk /system/app/superuser.ap
Reboot the phone
For those asking them self why do you need an Insecure boot.img, read here
http://whiteboard.ping.se/Android/Rooting
In theory this should allow you to be root user (adb is started as root), and push su/superuser to the phone/tablet.
System Partitions and overlay
/dev/block/mmcblk0p3 sys_boot partition (DO NOT PLAY WITH THIS PARTITION !!!)
/dev/block/mmcblk0p7 boot.img partition
/dev/block/mmcblk0p13 recovery.img partition
/dev/block/mmcblk0p16 persist partition
/dev/block/mmcblk0p17 system partition
/dev/block/mmcblk0p18 cache partition
/dev/block/mmcblk0p20 data partition
/dev/block/mmcblk0p21 media partition
CWM WITH ACCESS AT THE SYS_BOOT PARTITION ======>>>>> Bigger chance in bricking your device if you sleep while you flash something.
http://www.arctablet.com/blog/wp-content/forum-file-uploads/admin/2013/08/CWM50Plat-1.zip
CWM NON TOUCH / NO ACCESS TO SYS_BOOT
http://globula.arctablet.com/ARCHOS_50_PLAT/CWM_A50_Plat_NoTouch_No_SYS.img.zip
CWM WITH TOUCH AND NO ACCESS TO SYS_BOOT
Removed due to some bugs.
Adonis K.
Only the people from there, anyway I found the same method as them
And the method with the boot.img should be more safer.
Globula just helped me to root my 50 Platinum (running last firmware from 20130726) with the method from post #1.
There is an even easier method that can be used now, more on that soon...
2013/05/30
Is this compatible with the current (20130726) firmware update? Also, is there a way to install a recovery (CWM, TWRP or anything else)? Just asking because this method doesn't include that (There could be something like a follow up guide for it).
Hello, we just finished a perfect CWM 20 minutes ago .
Download link
http://www.mediafire.com/?v9lgmdeaktaiqds
Way to flash
adb reboot bootloader
fastboot flash recovery CWM50Plat.img
After you install the recovery, you can google for a SU zip pack and flash it using the recovery.
CarbonkidI'm adding a local mirror for globula file:
globula_neagra If you like our web site, applications and firmwares, feel free to support our site. Donations are used to pay the bills for our server hosting costs, development tools and purchase new tablets to support.
85 Guest(s)
Devices in use: Desktop (79), Phone (6)
smoky551
KarlAnkho
jasondweller
2256667898
EDINTELL
ilval
