2013/08/19
Thanks a lot for the effort, but I managed to do it myself - without Acronis, using the dd command in Ubuntu
Could you please post the details ? that may help others in the same situation.
Finally, glad that you took my approach .
In ubuntu when you have the phone in qualcomm download mode, multiple mount points will appear, you just need to know which one is the right one, and use the dd command.
The command to flash back should be something like
dd if=sys_boot.img of=/dev/sdx
Where sdx is the partition that you have to flash
I don`t recall the need of drivers in windows tough, On the 7C G3, it just appears a partition of 100 MB, which contains the AMSS.MBN
2013/08/19
Okay, I'll make a small tutorial this afternoon
The following users say thank you to DieterHolvoet for this useful post:
Could you please post the details to recover the device? that may help others in the same situation.
What the final solution in 2016?
2016/10/13
As far as i know,Android rescuer tool.which is designed for recovering lost data from android telephone, i have used it to recover the lost contacts from android phone of success , and without any risk, you can using Google to search it ,
78 Guest(s)
Devices in use: Desktop (74), Phone (4)
dnjakabssh
KaanFDS
jackthomas
hakhiem
jenom
kfwacky
