Archos 80 Platinum Root / Firmware
How to ?
ShafikTiesto
2015/09/07 - 23:11
Hello Zipboy thank you for this tutorial my tablet is fast now, I followed all the steps and that's work, perfect job man.
But i have one problem when i try to charge my tablet, in the screen i get "charging" but the battery discharges during time,
I notify that when I have flashed the tablet with Phoenix the battery was very low (10%) is that may cause the problem?
Any solution Thank you, (sorry for bad English )
zipboy
Forum Posts: 18
2015/09/08 - 20:15
Hello ShafikTiesto
You can use a battery calibration software (playstore). Calibration needs to be done after flashing a new ROM. This program does it by removing the batterystats.bin system file. Root permission is asked.
for exemple : https://play.google.com/store/apps/details?id=com.nema.batterycalibration&hl=fr
If it doesn't work, Try another cable (just in case).
I hope it will be helpful.
Bye
ShafikTiesto
2015/09/09 - 15:43
Thank you Zipboy for the answer.
I tried to fully charged the battery and re-flash my tablet with phoenix and the result was good,
the battery is charging perfectly.
Now my tablet is very fast and smart thank you again you save me !
zipboy
Forum Posts: 18
2015/09/09 - 19:29
You're Welcome. It's a pleasure to help.
Have fun with your new tablet.
Bye
moviescot
2016/04/16 - 15:19
I just found this today.  I have had an Archos 80 Platinum rotting away in a drawer as it had slowed to a standstill and was really frustrating.  I started this with no real idea if it would work or not.  I followed the instructions and it worked.  The tablet is now incredibly quick and I may now even use it.
Thanks for your details....
zipboy
Forum Posts: 18
2016/04/16 - 19:43
Hello moviescot
happy to read your post. Enjoy your new tablet.
Laugh
radar100
2016/06/01 - 18:49
Hello everyone!
I'm new here.
I have a Qilive 8QC which is manufactured by Archos and is equal to a 80 Platinum.
I tried to install the ROM 4.4
http://www.arctablet.com/blog/forum/onda-v812/rom-onda-v812-v1v2v3v4-hardware-android-4-4-2-kitkat-root-custom-firmware-v4-4/
but phoenixsuite says is not any connected device.
When I click on the upgrade phoenixsuite says "There is no Device to be upgrade!"
When the tablet is on with degub mode, phoenixsuite can see it but off does not connect.
What can I do?
Sorry my english but I'm Portuguese.
Thank you
zipboy
Forum Posts: 18
2016/06/01 - 21:59
radar100 said
Hello everyone!
I'm new here.
What can I do?
Thank you
Hello Radar100
Your tablet seems to be an Archos 80 B Platinum and not a 80 :
(http://www.arctablet.com/blog/forum/crewrktablets-rk3188-entwicklung-customroms-development-croms/qilive-8qc-archos-80b-platinum/?lang=fr).
So be careful, if it's the wrong firmware you will brick the tablet.
I googled for your model but i didn't find any custom firmware. Try harder than me.
Sorry.
radar100
2016/06/02 - 12:22
thanks for helping me.
I thought that there is only one Archos 80.
My Qilive has rockchip 3188.
Where can I find a rom for this chip?
zipboy
Forum Posts: 18
2016/06/03 - 19:38
It's seems difficult to find a custom rom for your tablet :
Read this :
http://crewrktablets.arctablet.com/?p=3555. Not confirmed for Qlive 8QC.
Be careful if you try.
If you have a problem. The Qilive Stock ROM is not available but the Archos Stock ROM work !
The HowTo : http://faq.archos.com/index.php?action=artikel&cat=125&id=68&artlang=fr (in french : use google translate)
The Archos Stock ROM for 80b Platinum :http://files.archos.com/recovery/fw/elements/archos_80bplatinum/update.img
radar100
2016/06/03 - 20:22
Again thank you for helping me.
I have already installed this Archos ROM and battery drains very fast. Lasts on average about 30 minutes. I've tried to calibrate the battery and did not work. Have tested another battery and it is the same ... The percentage of the battery fluctuates a lot.
I wanted to try another ROM to see if the cause is rom the Archos or some internal problem on board.
zipboy
Forum Posts: 18
2016/06/03 - 20:28
I think it's archos rom. They have very bad rom. It's why i change with the custom rom in this post.
Have you read this ?
radar100
2016/06/03 - 20:31
I will attempt to install this ROM and see how it works.
Thank you so much. Then return with news 🙂
radar100
2016/06/06 - 18:32
I installed the Rom but the wifi and bluetooth does not work.
Anyway I got to see the problem in the battery keeps with this rom.
The percentage fluctuates a lot. It is up and down. The tablet turns off saying it's no battery but if the power on on accuses 25%.
I do not know what's happening...
zipboy
Forum Posts: 18
2016/06/13 - 08:50
Hello
Sorry i wasn't there. As I said before this ROM isn't confirmed for your model. So, it explains why you have trouble. Perharps you will never find a good custom ROM. Come back to the original, and search another or follow evolution of the one you tried.
Good luck
113 Guest(s)
Devices in use: Desktop (111), Phone (2)
Twotrains
alexanddercrb
tsmfallen
TwiceBT
Alpifer
NavyMeso
