Archos G9 Firmware update 4.0.6 finally ready
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/05/03 - 17:33
Following the two test firmwares, Archos has released a minor 4.0.6 firmware update to their Archos Gen9 devices, which includes a few bugs correction.
According to the release information, the following changes are expected:
Version 4.0.6 – May 3rd, 2012
  • Wi-Fi: fix more disconnect cases happening on some access points
  • GPS: increase stability of GPS
  • HDMI: do not propose overscan setting when TV supports underscan
  • muSD: improve reliability of card insertion detection
  • muSD: fix read/write permission issue occurring with some applications
  • Applications: fix platform reboot occurring sometimes after a while when using high CPU demanding applications
Archos G9 4.0.6 Firmware download
firmware_archos_it4.aos (190 Mb)
Firmware update procedure at Archos.com
VanEllus
Yorkshire (North Riding)
2012/08/02 - 14:38
Hmmm — it didn't work. I downloaded to my PC, and then followed the instructions to load via USB into the main directory of the Arnova. When I disconnected, it did NOT offer to upgrade the OS. I re-booted the Arnova, but it still showed v4.0.3 in the About Tablet setting.
Moving to Explorer, I found the file, but when I tried to open it directly I got a Parsing Error message.
What now? It's not impossible that the download to the PC may have been a bit iffy, as we have tin-can-&-string broadband out here on the moors, and I used the link for other browsing during download. Do you think I should try downloading again?
exelletor
Blog Team
Forum Posts: 450
Thanks Received: 30
2012/08/02 - 14:39
This firmware will only work on Archos Gen9 models (101G9 & 80G9). Which device are you trying to install it on?
VanEllus
2012/08/02 - 15:59
Oops — I may have been reading the digits in the wrong order. This is an Archos 9G3... I was mis-reading the G9 bit.
Thanks for putting me right.
72 Guest(s)
Devices in use: Desktop (57), Phone (13), Tablet (2)
Mikewood
XSTR
aldi_2003
dtcinfly
Ultraprost
feasycom
