Tutorial: Flash CWM (Clockworkmod) 5.5 on Archos Gamepad
SgtxVortex
31
2014/01/06 - 18:38
im Trying to install it to the in my Gamepad there are no luck at all
First im Win 8.1 user i try in Win 7 Too
and at say's (No Found RKandroid) i did the recovery mode and everytime fail to install the driver i dont know where to put the driver come with file can you please tell me where i can put the driver's and thanks for the CMW :D
bateystyle
32
2014/03/04 - 02:44
hiya where is this software been looking and cant find it thanks
halix2000
33
2014/03/13 - 13:09
@bateystyle It's an attatchment on the first post of this thread. You must be logged in to see and download it.
kowalski181@hotmail.com
34
2014/04/21 - 15:51
i have the same problem i can see the drivers when i boot up but don't know how to get windows to recognise them
olanin
35
2014/04/26 - 14:21
I can only get the usb to connect in Windows 7 32-bit, try that if you are having trouble
olanin
36
2014/04/26 - 14:23
I seem to be stuck in "flashmode". How do I get out of it? I was able to FLASHROM with RKAndroidTool, but now my screen is blank and I can not get it to reboot or display anything. When I connect it by usb, RKAndroidTool shows it there, but thats all. What should I do?
Elyman
37
2014/05/04 - 18:06
Can anyone help me i tried installing the drivers but they didnt successfully install and now when i try to turn on my tablet it just stays on the load up screen and doesnt come on
blitzyuk
38
2014/08/31 - 16:11
Hi all
Are we able to use other versions of CWM on the Gamepad or is 5.5 the only version or can we use any other recovery mods?
All flashed and works perfectly.
I still think all android devices should come pre rooted be a whole lot easier.
yelever
39
2014/09/17 - 06:58
Either get stuck in flash mode or cwm reboot.  Can't get any further.
FrazUK
40
2014/10/26 - 18:58
Following this tutorial i just get to the part where it says "click flash rom" and that the tablet will then reboot into CWM aftewards. After clicking flash rom all that happens is i get a a bit of info in the right panel and the tablet does nothing. Just sits there lifeless and now i cant even switch it on. What am i doing wrong?
ElGuato84VE
41
2015/11/26 - 12:06
Thanks for the tutorial!
And thanks to all who helped to fix the "flash mode stuck problem"
64 Guest(s)
Devices in use: Desktop (52), Phone (12)
wogoko8553@yubua.com
hellander
elousstad
relaytester
revoltown
