Tutorial: Flash CWM (Clockworkmod) 5.5 on Archos Gamepad
totololo
2013/04/21 - 14:41
YEAH !!!
THANK YOU !!!
Now it works and I have been able to install Sigmax ROM !
nexxus86
Forum Posts: 15
2013/04/24 - 15:39
I'm not sure what happened, I followed the instructions, didn't check anything alse in the RK tool, but after flashing, my Gamepad won't turn on anymore and stays black.
I hold power for 10 seconds, hold it again, just stays black.
I can't even turn it on by plugging in the charger.
But I can still go into flashmode though.
edit: I had to reflash the stock image. seems like my Gamepad doesn't like CWM.
Thanks Received: 268
2013/04/24 - 16:04
reflash-it, using the restore option
JinSingh
2013/04/24 - 16:23
I had exactly the same problem this morning, as mentioned by someone else in an earlier post get the CWM from here
http://androtab.info/clockworkmod/rockchip/rk3066/
Download the Archos gamepad one.  Use the recovery.img in that zip file.  Worked for me.  Now running the JFG ROM.
The following users say thank you to JinSingh for this useful post:
ElGuato84VE
Nath4n
Forum Posts: 29
Thanks Received: 6
2013/04/24 - 18:05
JinSingh said ...
nexxus86 said ...
Yes, i posted this version CWM on first page. ;-)
nexxus86
Forum Posts: 15
2013/04/25 - 07:52
how do I flash the recovery.img? with the same tool that came with this CWM?
and do I need parameter and misc.img too?
Nath4n
Forum Posts: 29
Thanks Received: 6
2013/04/25 - 09:50
Just unzip RK tool and copy(replace) "recovery.img" to folder "rom". Then use the guide by sigma.nl
WonkyTrout
2013/04/25 - 10:00
Hi
If CWM recovery has been installed on a gamepad, is it possible return back to stock and remove CWM?
What steps are required?
thanks
2013/04/25 - 10:14
Yes, reflash the stock firmware provided by Archos
Either you put the firmware on the tablet, or you flash it with rockchip tools
benjo2410
Thanks Received: 3177
2013/04/25 - 10:24
Also, here is the stock ARCHOS GamePad recovery if you just want to flash it separately.
ARCHOS_GamePad_fw_20121227_stock_recovery.zip
Flash it the same way you'd flash CWM Recovery.
mrbeeks
2013/05/28 - 22:27
Guys stuck with Gamepad booting into CWM, ive installed Custom rom from zip then rebooted but ges back to CWM.  Any ideas? TIA
2013/05/28 - 22:46
re-flash the tablet using rockchip tools
mrbeeks
2013/05/28 - 22:52
I reflashed with archos recovery and now get update 4.1 runs  then it reboots and i get android robot on its back with triangle and exclamation mark.  any ideas?  thanks
Edit - Tried multiple things still no luck either stuck on dead android screen with exclamation mark
Can get CWM on but it just reboots after applying Sigmax from External SD card back to CWM
Not sure on what to do next Help Help Help,  Do i send it back?  TIA
Oh a thought can someone run a CWM backup which i can restore with? thanks
Drigz
2013/06/19 - 07:32
i'm currently in the same situation. if i use the troy or provided recovery its just a black screen (stuck in flashmode). if i use the stock it updates but then reboots into an android robot with the exclamation mark. if i use the androidtab.info's rockchip version it gets to cwm but it just boots back to cwm no matter what i do, with or without the new rom installed
EDIT:
I've also tried doing everything via ADB but I can never get the driver's to install (most likely because of Windows 7 x64) so it never recognizes the device when I do ADB Sideload within CWM. I've altered the ADB file to include the Gamepad but it still does nothing.
I'm pretty much at a dead end and any help is much appreciated.
argon0
2013/12/06 - 02:32
Well, I had the same problem, got the original recovery working, so that was fine... And then tried this one, which is CWM v6.0.3.1....:
The Archos Gamepad one from this page that is: http://androtab.info/clockworkmod/rockchip/rk3066/
Copied the recovery.img file to the location of the recovery.img provided in the zip in this thread, ran Flash ROM and VIOLA... CWM - now to try that custom ROM!
Cheers guys!
The following users say thank you to argon0 for this useful post:
ElGuato84VE
51 Guest(s)
Devices in use: Desktop (45), Phone (6)
thanhgom2006
hoholms
rammaiden
iongeorge411@gmail.com
legrandhommer
mindra
